Razor pocket rocket sprocket mod - Pocket Bike Forum - Mini Bikes
post #1 of 7 (permalink) Old 05-12-2011 Thread Starter
Hey guys I was wondering where I can change the sprocket on my pr200, do I change it in the back or on the motor? Can you guys please give me details on how many teeth this sprocket has, and how many teeth I need to make it faster. If you can please post a link.
rampotown is offline
post #2 of 7 (permalink) Old 05-13-2011
Trippin's Avatar
Re: Razor pocket rocket sprocket mod
front would be easier.
Dropping or adding 1 tooth is +/-3 in the rear
Dropping - better accel
Adding - better top speed
We dont need to tell ya the sprocket count, Im sure you can count it
Trippin is offline
post #3 of 7 (permalink) Old 05-13-2011
haydendlp's Avatar
X-TREME XP700 SCOOTER PARTS It is the xp700 sprocket the lowest tooth #25 chain wheel sprocket that I could find unless you get one custom made.Trippin you are right about adding teeth with the front sprocket would be better but unless you get a custom made sprocket,there is no motor sprockets that would fit the stock motor.Also the pr200 has a 55 tooth rear sprocket and a 11 tooth front.
Wheelie for speed
haydendlp is offline
post #4 of 7 (permalink) Old 05-13-2011 Thread Starter
by how much would that boost my top speed?
post #5 of 7 (permalink) Old 05-13-2011
Trip's Avatar
Images: 21
Rampotown check here for parts. > Razor PR200 Pocket Rocket Electric Pocket Bike Parts - ElectricScooterParts.com
There are plenty of front & rear sprockets that will work with your bike on this link. > Electric Scooter Sprockets - ElectricScooterParts.com
I'm not Antisocial,Society is Anti Me !
Trip is offline
post #6 of 7 (permalink) Old 05-14-2011
Trippin's Avatar
Try this to figure out your top speed when you change sprockets
Minimoto Garage - East Coast Minimoto Speed Calculator
Trippin is offline
post #7 of 7 (permalink) Old 05-14-2011
haydendlp's Avatar
It would boost your top speed 1-3 mph,realy you would be better off tuning(rotating the brush plate) on your motor, getting the sprocket custom made but you would be better off just adding a extra 12 7amp battery because that 44 tooth sprocket would not destroy your speed on take off.If you get one custom made you custom made that for example a 30 tooth sprocket and that would destroy your take off speed.
Wheelie for speed
