PZ19 Carb Tuning - Page 2 - Pocket Bike Forum - Mini Bikes
Outlaw
EPR's Avatar
Re: PZ19 Carb Tuning
Cam2 remember when they changed the diesel fuel, I was still in college getting a diesel certificate. I had my 10 wheel Kenworth w/ a Cummins turbo charged big bore. The new fuel was eating up the rubber seal in the fuel injection pumps, and the trucks were ready to kill the guy that made the fuel laws. Now, they are trying to make them pay $27,000 to add Smog stuff to there trucks,insane!!!
On the carbs, thats why like Cam2 I love Walbro carbs easy to rebuild and easy to keep in tune.
EPR is online now
Ninja Racer
BlitzMInc's Avatar
your supposed to tune a carb after it has warmed up to normal operating temp
the first thing to do is test the main jet, pilot jet, then the needle clip, then air fuel and idle
it also requires you to know what the bike is doing in certain ranges, idle, off idle to 1/4 throttle, 1/4 to 3/4 throttle and wide open throttle
the ethanol is killing carb jets, i used to be able to let my bike sit months without cleaning the carb, now its getting clogged in a few weeks
maybe if the gas was made of rice it would run correctly lol
Blitz's X15 - Ninja 110R aka Track Bike
YX 184cc, V2 head, decomp, Yoshi RS9 exhaust, 14/28 gearing, vee rubber race tires, S-Tech forks, dual caliper brakes, flipped swingarm with fastace shock, see my bike at http://www.youtube.com/profile?user=blitzminc
BlitzMInc is offline
Call Evil and it Appears
Originally Posted by f22master View Post
. Jetting is not a 'set it and forget it' thing.
Well said on that part,,Straight to the point ......................
To combat from always having to clean your carbs as often CRC makes an ethanol stabilizer you add to the fuel.........There are also drop in tank units that I use called FITCH... kit # F5T that lasts the lifetime of the bike and keeps the fuel refinery fresh............Ever since using the Fitch I havent had any carb problems the units are in.......On my F250 and 3500 series pickup trucks I have the Fitch inline units.......
Oh I remember it well...It wreaked havok on my 6.9 turbo diesel flatbed I had then...Some very tedious and expensive fixes for me at that time.....I think the DIP costed me around $1600 and the total job almost $3gs with me doing it myself........
Outlaw
EPR's Avatar
Thanks, going to have to look into that. Here in the rain forest the humitity is high even in the summer, so the Chinese metal wants to rust all the time,lol.
EPR is online now
Images: 3
I have a question regarding thosequotes if I just purchased a PC 19 rebuild kit if I rebuilt carburetor with all the supplies if hearts if I have the needle set on the leanest setting in the air fuel screw all the way in on my Carb and my bike is still running really rich is there anything else I can do??
bottlefed215 is offline
Outlaw
EPR's Avatar
Never heard of a stock PZ19 carb that is too rich, unless someone changed the main jet or you have an internal carb problem or something else is wrong.
EPR is online now
Images: 3
I changed the main jet to the main jet that came in the kit only thing that only thing that I didn't do was Dremel of the tab at the bottom of the fuel bowl so the float will be able how to go down a little farther and I'm getting good blow throug with my air tool for all of the hol with my air tool for all of the holes and openings in the carburetor I don't know what else to do I don't know what else to do other than to buy a brand new carburetor
Outlaw
EPR's Avatar
If you too rich your float level could be to high and to much gas is going into the carb and into your engine.
EPR is online now
Images: 1
What is the default jet set for a the Mikuni 22mm carb?
Pilot? Main?
I have not increased any yet because my X19 Loncin 110cc bogs on full throttle so is it running too lean or too rich? Idle is fine and the bike boogies at 3/4 throttle.....
Ryan
cwi2k00 is offline
Outlaw
EPR's Avatar
There is no works for everything set up. You have a choke jet, pilot jet, and main jet, and the 5 slot clip on the piston needle to make adjustments. Most of the time I have trouble with the bike cutting out and stalling and not running, the pilot jet is clog full of the crap additives they put in your gas and when you let it sit along time the gas turns to gum and clogs the pilot jet. It's very small, .018" to .020"
As the air gets colder you need a bigger main jet.
EPR is online now
Images: 1
Noted, thanks EPR! Bike is new along with carb and idles/runs fine except at full throttle. If I recall correctly I left the pin in the middle slot as recommended by tbolt usa tech data.....
I might be too rich on the main jet :-)
cwi2k00 is offline
Its most likely too lean..If it was too rich the engine would surge and literally Chirp aswell as foul the plug......The best way to actually tell is to literally pull the plug to see if its black brown or white......
Have you tried adjusting the a/f mixture screw to tune it in...?Thats what theyre made for......
Try turning the a/f mix screw outwards 1/2 turn richer and see if that makes it run better.,,,If not turn it 1/2 back in plus 1/4 more......
If it does start to run better and it takes 1 full turn outwards[richer] to get it running good get a bigger pilot jet 1 size bigger..Good Luck
Images: 1
Thumbs up Re: PZ19 Carb Tuning
Awesome thanks! Going with a bigger jet once I check the plug...I've tuned the a/f screw but doesn't seem to be enough....Thanks again!!
cwi2k00 is offline
Okay so I have some similar issues to a point. I have a Baja 90cc quad and i just completely rebuilt the carb. I have been looking online for a tuning diagram, but I cannot seem to find one. To the point now, I can get the quad started but it has an extremely high idle and if you don't hold the break it will actually start to take off on you. Then when riding it and having it at about half throttle it tends to just bog down and has a bad smell to it. Any ideas?
Carny13 is offline
hi can you tell me where can i find the manual factory settings i have a daytona dvrs50cc 4stroke
my carburetor is denipz19, as i know
GLAZ is offline
Outlaw
EPR's Avatar
That's a big carb for a 50cc bike, my X18 110cc had a PZ19 from the factory. The 50s had a 16mm carb.
EPR is online now
A 19 isnt too big for a 50cc as long as the carb is jetted right.....50's/70's90's and 110cc engines are built with E22 heads....My modded CRF70 had a 20mm carb.....It was jetted 40/85
Fuel/air adjustment screw is 2 full turns out
C-clip setting is middle notch[3rd]
Float setting is -10 degrees
pilot jet is # 38 factory
main jet is #73 factory
Thanks, but i must say that when i turn the fuel/air screw at 2 turns out or 1 and a half or 2 and a half, the bike at 40 and at 50 kilometers per hour with 3rd or 4th gear sometimes does like it is going to stop and come up again very quickly, like back and forward, in steady throtle only.But it opens speed very well when i open throtle ,with out this symptoms like in steady throtle. I could say that it runs better with fuel/air screw at 1 or less turns out.
Some of our mechanics here say 2 turn out , other 1 and a half , other 2 and a falf and other say it doesn't matter the turns in or out, as far as it works better.
I dont know what to do.
GLAZ is offline
The guy that says it doesnt matter how far is half right.It kinda does matter..
If you have to adjust the carb more than 1 1/2 turns in either direction from factory setting to make the bike run right you need to rejet accordingly then start over from the factory preset after rejetting..............
Factory setting for starting over is 2 full turns out everytime.........
Id adjust the a/f adjust screw to 2 1/2 turns out and set the c-clip to the 4th notch............Id also do the float restrictor tab removal mod and upgrade the fuellines/fuelfilter to 1/4"................Good Luck
