Leaf Blower - Pocket Bike Forum - Mini Bikes
post #1 of 20 (permalink) Old 04-25-2006 Thread Starter
Leaf Blower
ok, i know this is a pocket bike forum but i have a question about a leaf blower engine and i know you gise know alot about engines so answer please. ok, i had the leaf blower for only like 3 days and all of a sudden it would never start and it started perfectly before. whats the problem?
*please dont delete forum*
kevin_king is offline
post #2 of 20 (permalink) Old 04-25-2006
Images: 28
Re: Leaf Blower
ya ran out of gas..........................
Backwoodz is offline
post #3 of 20 (permalink) Old 04-25-2006 Thread Starter
Re: Leaf Blower
i have gas.
post #4 of 20 (permalink) Old 04-25-2006
Re: Leaf Blower
are you using the choke?
wtpbmx2003 is offline
post #5 of 20 (permalink) Old 04-25-2006 Thread Starter
Re: Leaf Blower
yep..help me
post #6 of 20 (permalink) Old 04-25-2006
Re: Leaf Blower
maybe theres something wrong with your pull start. does the spark plug have a spark?
post #7 of 20 (permalink) Old 04-26-2006
125ccCRazy's Avatar
Images: 10
Send a message via Yahoo to 125ccCRazy
Re: Leaf Blower
Well the therory is that if it has gas and spark it will run or at least start unless there is something mechanically wrong like a hole in the piston, broken key in the flywheel ect....check for spark, could be a fouled plug, if it has good blue spark try pouring an ounce of fuel in the carb, possibly the diaphram in the carb is bad..If those check out do a compression test, the piston may have a hole in it or the rings broke....This problem will be a process of elimintation..
125ccCRazy is offline
post #8 of 20 (permalink) Old 04-26-2006
puppetmaster's Avatar
Re: Leaf Blower
well what i do when all else fails is put in on ground say a few profantities at it and start to kick it untill it starts..lol...
no seriously did you break the engine in properly. it usually says in the manual to use a certain mixture ratio for break in period and then change the ratio. most likely the piston is fried. take it back and get a new one. hope this helped.
puppetmaster is offline
post #9 of 20 (permalink) Old 04-26-2006 Thread Starter
Re: Leaf Blower
yes i did all of that and how do i test the spark plug?
Re: Leaf Blower
sounds like a craftsman leafblower had the same problem with mine never could figure it out now i have a stihl and it works great
photo is offline
post #11 of 20 (permalink) Old 04-26-2006 Thread Starter
Re: Leaf Blower
i use the choke, the spark plug works. im not sure why it doesnt..
post #12 of 20 (permalink) Old 04-27-2006 Thread Starter
Re: Leaf Blower
yes i am usin the choke and my spark plug works.
Images: 2
Re: Leaf Blower
hmmmm.well r u sure dat u got da rite mix? I work on Mowers weedeaters.etc. my blower had da same problem and it needed an idle ajustment.
Hope this helps
ScooterJunkie is offline
FatalError's Avatar
Re: Leaf Blower
Why not just take it back in the first place? I couldn't see anyone arguing with you over it at the counter. Or is this a garage sale item? =)
FatalError is offline
post #15 of 20 (permalink) Old 05-04-2006 Thread Starter
Re: Leaf Blower
i threw it and broke the plastic a bit when it wouldent start. lol
FatalError's Avatar
Re: Leaf Blower
Oh, well you still might as well take it back. Just tell them it came that way, just like the rest of the lying public does. People used to bring me back dead fish when i worked at petsmart years ago, & try and tell me they came like that. Although im pretty sure i'd never bag up a dead fish for someone, But you'd be surprised what you can get away with as a consumer/customer. Not really any help, but still a messed up story. =)
post #17 of 20 (permalink) Old 05-04-2006 Thread Starter
Re: Leaf Blower
hahaha.. you seem smart.. go to my thread in 2-stroke mid-bikes (i think you already are if you looking at this) and look at my thred on weird noises and please help me.
Re: Leaf Blower
I think i might know what your problem is you have to plug it in to an outlet because cause you bot an electric one you got to plug it in man that will solve all your problems.
derek920 is offline
Re: Leaf Blower
I'm pretty sure there isn't a leafblower that is both gas and electric, and if so I have never heard of it. And he stated earlier that it was gas, so plugging it in won't help. so I would ignore that response.
Lastshot is offline
Mblough's Avatar
Images: 4
Re: Leaf Blower
guys look at the dates on the posts before you yourself make a post. posting on this one was on the brink of grave digging (dead thread revival).
this thread is like a month and a half old. im sure by now the poster eiterh figured it out, sold it, or gave up.
Mblough is offline
cheap and easy turbo ABCDEF G-unit Air Cooled Pocketbikes 21 12-31-2005 08:45 PM
X 12 mods jamesdem1123 4Stroke Midbikes 6 06-05-2005 06:55 PM
