X7 wiring diagram - Pocket Bike Forum - Mini Bikes
post #1 of 23 (permalink) Old 07-11-2008 Thread Starter
X7 wiring diagram
I looked over alot of posts on here and didn't find anything showing a diagram of the x7 wiring, i recently got one handed down to me but the speedometer,front lights, and blinkers dont work. Anyone know where i can get a diagram for this bike? or have enough knowledge on x7's to maybe help me rewire it alittle.
Thanks
Shiester is offline
post #2 of 23 (permalink) Old 07-11-2008
dragonkeep2000's Avatar
Re: X7 wiring diagram
the x7 is the same wiring diagram for the x2,x3,x5,x6,x7,x8,x9 and the cateye ......all of the 2 strokes were the same wiring systems all except the x1 which some of them did not have all the lights that the others did.........i would rather buy a wiring harness for 25.00 new than take a chance of frying the system by accidentally touching the wrong wires together............
dragonkeep2000 is offline
post #3 of 23 (permalink) Old 07-11-2008
125ccCRazy's Avatar
Images: 10
Send a message via Yahoo to 125ccCRazy
no such thing as a diagram for these bikes since the chinese have NO consistency to the color codes... The harneses change color from one side of the plug to the other and from bike to bike... All you can do is get a test light and start testing wires, my guess would be something came unplugged... Buying a new harness would be useless unless you got every wire for all the lights, controls ect as the chances of another harness plugging into all your connections is slim to none, somewhere there will be a different connector, it's like they wire each bike individually....
I rewire all our bikes so I know what is what and where.....
If you touch a hot wire to a ground all it will do is blow the fuse since everything electrical is run through that one fuse, you wont fry a harness unless you take the fuse out and shove foil or a screw in place of the fuse...These harnesses are not that suficticated, just confusing...
125ccCRazy is offline
post #4 of 23 (permalink) Old 07-11-2008
it will be easier to change a plug end than to rewire the whole thing ...besides you will already have the messed up harness to pull all of your plug ends from anyways............and all 50cc cdi's ,rectifiers and relays all plug into the wires the same all you need to check are the lights and signal plugs..
post #5 of 23 (permalink) Old 07-11-2008
125ccCRazy's Avatar
Images: 10
true but trying to figure out what goes where is the pain, nothing is color coded, when you rewire it yourself you know what goes where... It's an easy job plus you can wire in more than one fuse relays for higher watt bulbs, alarms, NOS, whatever you want to hook up...Thats just my thing when it comes to the nightmare wiring on these bikes..
post #6 of 23 (permalink) Old 08-17-2010
how do i know if i need to change the cdi or the wire harness?
zaporozhets is offline
post #7 of 23 (permalink) Old 01-13-2012
where does my ignition coil plug plug into?
choebikestudio is offline
post #8 of 23 (permalink) Old 01-14-2012
Outlaw
EPR's Avatar
Here is a couple off wiring dia. they may be modded wiring but they will give you a general idea. Starter System and a modded stripped wiring I believe. Hope this will help you, wiring is not my Gig,lol.
post #9 of 23 (permalink) Old 02-21-2012
In the top diagram what is the thing that is not labled that everything goes in?
jchaussee is offline
Also I have a mini pocket bike that looks similar to a cateye. Does anybody know what it is and have a pic of what it is supposed to look like?
Outlaw
EPR's Avatar
I believe that black box and the 4 wire connector above it is the voltage Regulator, ( rectifier ) . See how all the power goes thru there.
Hey, I was wondering when i got a cat eye pocket bike .The fuse wires was rigged up i was wondering if you can tell me what are the orignal color for the fuse wires are supposed to be on the bike please and thank you ????
mijo72 is offline
so i could use a wiring harness off the x7 (2stroke) to plug right into my cateye fs 509? just some colors may be differant?
fs-509 is offline
bullwinkle0689's Avatar
Images: 3
i have a diagram. email me on flamin_hotdog@hotmail.com and i will send you it
bullwinkle0689 is offline
Images: 3
scratch the email, here ya go
ok so i spent another day trying to wire this im about to give up i did mamage to find a wiring harness on ebay but its for the x1 x2 would this work for my bike i have the fs 509 / z600 / cateye ?
fs-509 is offline
Outlaw
EPR's Avatar
X1 has no light wires etc.
ok thank you what would the best harness to get? im just over thinking this wiring to much and confusing my self
fs-509 is offline
Outlaw
EPR's Avatar
I think X2-X7, 2 stroke wiring would work. Everything that gets power goes to ground after, like your lights, key, coil. All my bikes the green wires all go to ground, and most bikes have a bunch of green wires tied together, an is grounded to the frame w/ a bolt. Alot of hot wire stuff could come off the key switch, or voltage regulator. If the stuff on the bike has plugs and your new wiring has plugs, most are different, 2,3,4,5 and 6 wire plugs are common, for the stator and other things. Go to pocketbikeparts, or maybe scooterparts4less. Look at wiring diagram, find where the hot wire comes from on each part and do them 1 part, 1 wire at a time.
Images: 3
on my x2, the only green wires where providing a live feed but they where green and white
