how does gearing/ sprockets work? - Pocket Bike Forum - Mini Bikes
post #1 of 11 (permalink) Old 08-08-2007 Thread Starter
How do sprockets work?
Does a bigger sprocket in the back give u top speed or acceleration?
Does a smaller sprocket in the front give u top speed or accerleration?
X1racer_va is offline
post #2 of 11 (permalink) Old 08-08-2007
Re: how does gearing/ sprockets work?
a large sprocket in back with incress top speed a smaller reaer sprocket with give u better acel and less top speed but id perfer top speed
exposed87 is offline
post #3 of 11 (permalink) Old 08-08-2007
Exactly. Big rear sprocket-top speed. Small rear sprocket-hole shot
giverrr is offline
post #4 of 11 (permalink) Old 08-08-2007
Excommunicated PBP Staff
Images: 4
No, actually its the complete opposite. Bigger rear sprocket better acceleration, smaller rear sprocket better top speed. Small front pinion better acceleration, larger front pinion better top speed.
Please do the research before you answer someones question, it just makes you look like an idiot and it feeds noobs with the wrong info.
minimotoracer311 is offline
post #5 of 11 (permalink) Old 08-08-2007 Thread Starter
>.< u ppl are all sayin diff stuff. What is the correct answer to my question?
post #6 of 11 (permalink) Old 08-08-2007
minimotoracer just told you.
swanni06 is offline
post #7 of 11 (permalink) Old 08-08-2007 Thread Starter
ok i will go with what minimotoracer is sayin.
post #8 of 11 (permalink) Old 08-08-2007 Thread Starter
so if i get a bigger rear sprocket and a smaller front sprocket my bike should accelerate much much faster?
post #9 of 11 (permalink) Old 08-08-2007
what size is your front pinion? count the teeth on it and see.Its easier to change the front pinion gear because you won`t have to worry about messing with the chain size.plus just buying a new pinion/clutch bell combo will be cheaper than a rear sprocket and chain.
swanni06 is offline
I wrote that the big rear sprocket gives better acceleration and a small rear sprocket gives top speed and edited my post when I realized someoen else had posted. Sorry I was doing something and should have left it alone rather then assume the post sbove me was correct and agree. Yes X1racer va it will accelerate quicker. Darn caffine
giverrr is offline
post #11 of 11 (permalink) Old 08-08-2007 Thread Starter
my front sprocket is the stock one. I think it has 14 teeth. I have only found bigger front sprockets for better top speed. I found a 20 tooth front sprock that said it would make my bikes top speed 40% faster but much less acceleration. Where can i buy a smaller front sprocket for faster acceleration?
