hOW DO YOU TEST IF THE SPARK PLUG IS FIRING - Pocket Bike Forum - Mini Bikes
post #1 of 6 (permalink) Old 11-29-2009 Thread Starter
How do i test if the spark plug is firing? Do i take out the plug from the head and while its still attached to the coil cable do i give the pull start a tug?
deadsoulja is offline
post #2 of 6 (permalink) Old 11-29-2009
rider110's Avatar
Re: hOW DO YOU TEST IF THE SPARK PLUG IS FIRING
I had the same problem but Nick J told me how to, heres how and i quote:
"Pull the plug out, put the rubber boot back on the plug, hold the boot and plug (by the rubber boot so you don't get a little shock) touch the metal thread section of the spark plug to a metal section of the engine or frame and pull the pull start while looking for a nice blue spark."
hope this helps,
rider110
rider110 is offline
post #3 of 6 (permalink) Old 11-29-2009 Thread Starter
thanks been a gr8 help will try now many thanks
post #4 of 6 (permalink) Old 11-29-2009
rider110's Avatar
No problem
rider110
rider110 is offline
post #5 of 6 (permalink) Old 12-01-2009
NASAguy's Avatar
ya i did and i shocked the hell out of my hand well it was a car so
goped $650
dirt for a jump $12
getting your balls slammed into the handle bars pricless :)
NASAguy is offline
post #6 of 6 (permalink) Old 12-02-2009
Call Evil and it Appears
hope this helps,
rider110
In addition to what NickJ has stated you should also hold the plug in the boot 1/2-3/4" away from the engine fins and see if the spark can jump the 1/2" -3/4" gap to ground...If the coil isnt powerful enough to make the spark jump check your flywheel magnet and pickup coil for rust and proper spacing within the airgap between the two...Optimal gap is the thickness of a true business card.If the flywheel magnets,pick-up coil and air gap is good it may be time to replace the coil....One sure test is by disconnecting the killswitch and using starting fluid to see if you get a kick.......................Peace
CAM2 is online now
