Electric starter - Pocket Bike Forum - Mini Bikes
 1Likes
  • 1 Post By EPR
post #1 of 9 (permalink) Old 1 Week Ago Thread Starter
Electric starter
So I just fully charged my battery and trying my electric starter and it'll just make a click noise then I'll hold the left brake and it'll make a lot of clicking noises kinda like it's farting, what could be the issue? Thanks guys.
Sent from my iPhone using Tapatalk
zombiehatter is offline
post #2 of 9 (permalink) Old 1 Week Ago Thread Starter
Re: Electric starter
Anyone have any info on electric starters ?
post #3 of 9 (permalink) Old 1 Week Ago Thread Starter
I'll post a. Video when I get home at 9 pacific
post #4 of 9 (permalink) Old 1 Week Ago
Outlaw
EPR's Avatar
Find your starter solinoid, short across the two big posts to see if the engine turns over. If it does you have a bad one. The starter is also a generator, it has 4 brushes, two for starting and two for making power to charge the battery. The armature could be bad or your brushes worn out. There not very good quality. We all take our starter housings off and just use the rope starter. The housing & magnets add a lot of weight and the magnets rob power from the engine.
You could run LED lights off the battery and charge the battery when they get low.
post #5 of 9 (permalink) Old 1 Week Ago Thread Starter
Video of it
post #6 of 9 (permalink) Old 1 Week Ago Thread Starter
My bike can only go 20-25 max lol wish these 49ccs were faster
post #7 of 9 (permalink) Old 6 Days Ago
Outlaw
EPR's Avatar
You need a 6hp piston port instead of a less than 3hp stock engine. Sounds like your battery does not have the amps to turn over the engine. If it sat for more than a month and the battery level dropped to low the battery is no good even if you charge it and it says 12 volts, got to have them amps. Charge your battery full and have it load tested at an auto parts store. It's like a car battery have to keep it fully charged 24/7 or it will go bad. I keep float charger on my batteries in the winter, when the 12v ( 13.7 volt ) battery drops below 12.5 volts it charges it back to 13.7.
zombiehatter likes this.
post #8 of 9 (permalink) Old 6 Days Ago Thread Starter
So here's a video of what it's doing now man, let me know what I should do
post #9 of 9 (permalink) Old 6 Days Ago
Outlaw
EPR's Avatar
I still think you need a new battery, you can here the starter solenoid clicking trying to turn over the engine, and the battery cannot produce enough amps to turn it over. You need a $7 voltmeter from H/F Tools so you can test the wires and voltage. New, the big wire off the alum starter housing puts out 13.7 volts running, if the meter reads 12.5 volts or less, time to look for a new starter housing unit. Here is a hot rod engine I just finished.
