Where do i put the oil in the X-12? - Pocket Bike Forum - Mini Bikes
post #1 of 6 (permalink) Old 04-23-2010 Thread Starter
Question Where do i put the oil in the X-12?
just bought a second hand X-12 Super pocket rocket, idk where to put the oil, there is a oil hole next to the kick starter but my dad thinks that is for the crank case oil, any ideas?
mok420 is offline
post #2 of 6 (permalink) Old 04-23-2010
Kieran's Avatar
Re: Where do i put the oil in the X-12?
the crank case is where you put the oil.
Kieranm1994 my youtube name, take a look.
Owner of a 47cc cag, that starts first pull. Now thats an achievement
Kieran is offline
post #3 of 6 (permalink) Old 04-23-2010
114cc MC w/ Joanna
guruhelp's Avatar
Images: 10
Send a message via Yahoo to guruhelp
Yes, unscrew that thing that's in the hole and you will see it's a "dip-stick"...{WHACK} JIMMY!
guruhelp is offline
post #4 of 6 (permalink) Old 04-24-2010 Thread Starter
guess i should start thinking with my dipstick, ok, another question, what kind of oil goes into it? and also, could old/bad oil cause for rough shifting?
mok420 is offline
post #5 of 6 (permalink) Old 04-24-2010
114cc MC w/ Joanna
guruhelp's Avatar
Images: 10
Thumbs up Re: Where do i put the oil in the X-12?
although 5w-30 is recommended, I use Mobile 1 for motorcycles, 10w-40 and haven't had any shifting problems at all.
Useing automotive oil is not as good because motorcycle oil has more polymers, fillaments like spaghetti strings that get chopped up by the gears in the transmission of a motorcycle, since the same oil is used for both engine and transmissions, except on Harley's v-twins. That kid of oil lasts longer and works better. Your bike will thank you!
guruhelp is offline
post #6 of 6 (permalink) Old 04-24-2010
Ninja Racer
BlitzMInc's Avatar
what i use
Blitz's X15 - Ninja 110R aka Track Bike
YX 184cc, V2 head, decomp, Yoshi RS9 exhaust, 14/28 gearing, vee rubber race tires, S-Tech forks, dual caliper brakes, flipped swingarm with fastace shock, see my bike at http://www.youtube.com/profile?user=blitzminc
BlitzMInc is offline
