Clutch will not engage until high RPMs - Pocket Bike Forum - Mini Bikes
post #1 of 2 (permalink) Old 10-21-2004 Thread Starter
Send a message via AIM to JohnnyPsyber
Wink Clutch will not engage until high RPMs
Just got my C1 the other day, started right up, but the clutch doesn't seem to engage until I bring it up high RPMs. Even when it's just on the stand. I adjusted it and it was a little better, but the power just wasn't usable that high in the RPM. I already plan on ordering a Polini clutch, but was wondering if this has happened to anyone else, if so what did you do to fix it? Also, just wondering if there was anything else I needed to put in a Polini clutch, other then a spring set. Thanks
-Johnny
JohnnyPsyber is offline
post #2 of 2 (permalink) Old 10-21-2004
jsigone's Avatar
Images: 6
Send a message via AIM to jsigone
the clutch is suppose to engage from 8200 to bout 9400 pending on the clutch and material u use. Its somehting to get use to. If u make it engage sooner, the bike won't be making power so it won't move u.
jsigone is offline
Different Clutch, No Timing key ???? Mischief Air Cooled Pocketbikes 7 06-29-2005 04:23 AM
High revving clutch Marto Water Cooled Pocketbikes 6 12-23-2004 03:43 PM
Cheap/Good C1 clutch fix BungeeGuy Water Cooled Pocketbikes 6 11-15-2004 12:35 AM
Fluttering at Mid to High RPM's Ride Like You Stole It Air Cooled Pocketbikes 26 10-10-2004 10:30 PM
What RPM's should the 1.5 springs engage at? SUX2BU Air Cooled Pocketbikes 5 09-20-2004 02:47 PM
