I'm at approximately 0. I'm at sea level. south Florida. you are basically at the same altitude as the ocean.........sea level.
hummm....we'll have to play with the air screw then. as well as the petcock.
but why would the petcock only affect the WOT at 5th gear?
it may be the main jets. maybe they are clogged? aren't the main jets the ones that operate at the higher gears? at WOT?
Originally Posted by badazztoyz.com what altitude are you at? have you swapped carbs maybe? if its wot its usually the main jet or could be air screw adjustment etc. Id swap carbys and put in a new plug and run it 5th gear wot then after it shuts down pull the plug and see what it looks like. I havent messed with these bikes enough to give a way to troubleshoot it but i can give you general diagnosis for a two stroke. Take apart fuel petcock too and make sure theres no crap in there |
