Most of the electric PB's will have somewhere between a 500-800W motor and can last for up to 15 miles, but top out at around 30, maybe a little over.
An ETEK'd powered PB will top out at over 60, but the range is going to be a lot lower. The ETEK's are awesome to race and to go fast. But to go for range you'll need bigger batteries.
If you're used to cruising at 40 or so, you won't be happy with a 30MPH electric PB. An ETEK'd bike could give you a 20 Mile range, if done right, and riden carefully, but would take a good 4 to 6 hours to recharge.
Hope that helps...
Originally Posted by AtomicBiker no.
Your AVERAGE electric bike won't do 40 (look at higher wattage 700-800W). On average, they run for about an hour and a half, and it takes about 6 hours to charge. |
