MX650 mods?
A new drag bike
Xp-700
help with razor pr200 set-up
Electric X7
"That Black X1"
Old 07-30-2008
Charging Issue
I upgraded my Mx500 to 48v. the stock batteries were is bad shape and wouldn't charge, so I ordered a new set from Razor.com. I connected em all up right, and plugged in the charger, and the green and red lights on the charger are on. Doesn't that mean that its not charging?
Old 07-31-2008
Re: Charging Issue
no that is it is fully charged when grean/red...ride the bike very lightly and discharge the battery for like 5 mnutes of slow riding(very easy on the take offs) then try and charge the batteries again..should work then
Red/Red is charging
flashing red's battery is bad or charger failure
Old 07-31-2008
Re: Charging Issue
i did what you said, and the green and red lights are still on. when i plug the charger into the wall, the green and red lights light up too. isnt supposed to change from when its unplugged from the bike and when its plugged?
Old 08-01-2008
Re: Charging Issue
I was riding the bike, and all the sudden the batteries got low and the bike stopped going....i dont think its charging right.....HELP ME!
Old 08-02-2008
Re: Charging Issue
call the company you got it from and request another charger...that one is not functioning correctly(was it TNC?...they sure sell a lot of junk, but they are happy to work things out and send another one to you....lack of testing on ther part it seems)
is the bike fast any? it will do 23mph to up to 25mph if your still going 18mph the batteries are not charging and the controller voltage protection is kicking on to save the batteries....
do you directly charge the batteries or use the stock charging port?
Old 08-02-2008
Re: Charging Issue
no battery connected will be red/red when you have it plugged in the wall and not to the bike....it really does seem like you got the shaft for that charger...dont act pissed when you call them, if your nice to them they will kiss you aS$ with service
Old 08-02-2008
Re: Charging Issue
Lol..sweet, Um yeah it does go fast, but only for about 2 min.. the it shuts down and goes super slow. and i tried charging them directly and with a new charging port and nothing.
Old 08-02-2008
Re: Charging Issue
Stop riding it, you will hurt the batteries if you take any more juice outa them... get the new charger very soon...like tell the company it is very very urgant you recive your replacement charger soon!
  #9
Old 08-03-2008
Re: Charging Issue
whats the worst case scenario? i just spent 70$ on batteries and i do not want to buy new ones.
  #10
Old 08-03-2008
Re: Charging Issue
yup...but you have a 1week to 3 week window when the controller tells you the batteries are bad....
do you have access to a car charger?(computer AGM/GEL/ACID) if so disconect the main power take the batteries out and charge them individualy at very low amps(NO greater then 2amps)...as long as the battery pack is not plugged in you can just take the charger clips and go down the line with the batteries(one at a time) it should take about 45m-1.5 hours to do it....
NOTE: dont do this with a old school battery charger that does not have a charge brain and an option for gel batteries or you may burst a cell...very bad..GEL batteries if they explode they have a very sticky acid and the gas's thack come out from a venting gel cel are not that healthy
  #11
Old 08-05-2008
Re: Charging Issue
I do not have a charger like that. And TNC won't send me a new one >.< I will order a new charger A.S.A.P.
  #12
Old 08-18-2008
Re: Charging Issue
dont do that i just bought a battery tender also make sure when you connect the two circle metals make sure the bottom part of the metal is getting charged. if it is charging once you connect it for a second the red light should flash then stay there for a couple minutes then after that the red light should off and it might keep appearing because when the red light comes it means it has dropped a volt to the battery or it has done charge and you will know trust me write back to me if it works man iight
Page generated in 0.41289 seconds with 48 queries
