Originally Posted by streetridaz "A 150amp controller that will only get the 30amps max that the 12volt 7ah gel cell. Hmmmmm? Where is the extra amps you speek of?" http://www.scooterparts4less.com/web...8v_charger.htm
Well not really understanding that, but i think our answer is in one of the same. He will see a power increase with just a new controller. Now will that increase be a big one? No! he does't have the powerplant nor the fuel to see it's real benefits. but your idea I don't think is really helping him. He doesn't want to get involved with really modding the bike and or having to fabricate and stuff.
He's going to have to get a different motor and fabricate a mount for it. Hes got to wire up the batteries and the controller with a charger series. I don't have a clue where you found a 48volt fast charger for 30-35 bucks that charges in 2 hours but please share if you have. lol and a 50 amp controller, he's already got a 30amp if i'm not mistaken. That is nothing in the power department while running 48volts. Then there is all the extra weight he's loosing run time. I think his best bet is just gonna be a new controller and maybe a replacement 350 that should bolt right up. |
you came up with this great idea that to use hose clamps, good idea by the way! that can get any one to buy a new motor.
also the charger is the Panra 4.5 amp charger..
http://www.scooterparts4less.com/web...8v_charger.htmcharges 48v12ah set up in less then 2 hours. Also Amps dont make the bike go faster, it is voltage. Then on the other side of things a 12volt controller would need more amps to get the kind of speed and power a 48volt50amp controller. That 48v50amp controller is the best for the money....
a likle spaz
look at a 24-36volt 100amp TSP100 they sell for $130-150 new, it is a very high end solid state low cost controller. I do belive Streetz uses this one in his bike.
The parts list I posted is the best option for you
1) Four(4) 12volt 7amp hour gell cells $15-20 each(you only need to buy two)
2) 50amp 48volt controller $35
3) 48volt fast charger $30-35 (just over 2 hours)
4) 500-700watt 36volt motor $40-45
