The 90T sprocket can be had cheaply at
All Electronics | Electronic and Electro-Mechanical Parts and Supplies at Discount Prices, but it is not a direct fit. The center hole has to be enlarged and four holes have to be drilled around it in the same pattern as the stock sprocket in order for it to fit.
The chain will also most likely have to be lengthened aswell. The MX650 has a chain tensioner, but I doubt even with it removed that you wouldn't have to add more links to the chain.
I don't know about the new top speed, but it will definately be slower.
