Hi Guys,
I just wanted to let everyone know what I’ve been up to. I’ve upgraded my Son’s MX500(MX1200) again…
If you read back in this thread, you may know I had upgraded my Son’s MX500 to a 1200w motor 48v 100a controller with 12ah batteries. It was a great upgrade, be we have been putting up with a few issues ever since. Whenever my Son would nail the throttle from a stop, we would get some engine stumble, “Tah.. Tahh Tahhh” before it would go like normal. We also noticed the battery life was only like 15-20 minutes, when he was riding hard..
Ok, so up to the latest upgrade. I tore the bike down, and rebuilt it. This time I stuffed in 2X the batteries (2 12v & 2 36v) making it 48v at 24 amp hours. This required me to slightly notch out the upper front frame brace – to make the last 12v battery fit, but I got it all into the standard engine area. I then added 3 inches of lift to the rear suspension, with a lift kit bracket I fabbed. The results are amazing. The bike sits higher, There is absolutely no more engine stumble when using the 100a controller, he can ride it hard for 35-40 min, and the thing will pop wheelies to no end - with our 90t rear/ 11t front sprocket setup (8.2:1 ratio). The thing has so much torque, it’s literally amazing! Even with me(175lbs) and my buddy(250lbs) the bike goes like a rocket out of the hole!
My son was next interested in top speed, now that we have the power. So, I set it up with a 80t rear / 22t front sprockets = 3.64:1 ratio. We took his bike to a straight safe closed road, and let it all hang out… 42MPH top speed !!!!!!!!! Check out our latest vids on youtube. Search for “mkroberge”
It was really cool seeing how fast it would go, but after that one speed outing, we are going to switch back to 80t rear/11t front stock gears. These bikes are really “toys”, and by no means should be going this fast on a regular basis.. *By my calculations, the 80t/11t combo should give us a top speed of ~22-24mph, with plenty of low end torque.
See my attached
photos of my latest upgrade
-Miker71
