MX650 mods?
A new drag bike
Xp-700
help with razor pr200 set-up
Electric X7
"That Black X1"
Old 08-12-2008
need wiring help please
i got lots of power in battery,brand new battery,checked it and has lots of juice.there doesnt seem to be any fire coming out of the regulator on it,i phoned monster scooter parts and they said its not a (3 series) and will have a hard job finding one.is there any way to bypass this,or any help would be great.ty
Old 08-12-2008
Re: need wiring help please
its an 18volt honda minimoto btw
Old 08-12-2008
LoL, not the normal lingo, but let me see what i can do with it....
Regulator? do you mean motor/power controller? (brain box of electric bikes) if so, you may just need to check a fuse and or reset the breaker, if this does not fix it, check the wires/connectors for any damadge or loose fitting problems....if this does not fix the problem, then you may need a new controller, if ou have laready bout a new controller then here may be your problem
wire codes:
"main power"
14-12ga red = (+) power in to controller
14-12ga black = (-) power into the controller
"motor power"
14-12ga blue (+) power out to motor
14-12ga yellow (-) power out to motor
"off/on"
red/black wires(small 22ga) not needed
"break wires"
red/black(small 22ga) can be up to 2 sets (dont need to use them if you dont want to(cleaner look as well)
"twist grip wires"
Controller then to twist grip chart:
(controller:twist grip)(((three wire hook up,standerd wireing set up)))
red:red (volts in)
black:yellow (volts in)
green/blue:wight (control out)
all other wires I have never used, these are the main connection wires needed to connect a controller into a bike
Old 08-13-2008
yeah thanks.i already know its the controller,was wondering if there was a way to bypass it because i cant buy one to fit it and dont want to spend alot of money on it....any tips?
Page generated in 0.19103 seconds with 24 queries
