Here are the specs on the Etek:
20 HP Peak, 8 HP continuous
Voltage........................50 VDC
Max Nonload Current.....6 AMP
Max Nonload Speed........3600 RPM
MIN Nonload Speed.........3300 RPM
Min Speed at 160 Lbln.....3200 RPM
Max Current at 160 Lbln...150 AMPS
Shaft Size .......................7/8" Dia. 1 3/4" long
Voltage Constant: 72 RPM per volt
Torque Constant: 1.14 in lbs/Amp
Continuous Current: 300 A 30 Sec.
Weight: 20.8 lbs
Motor Diameter: 7.91"
Motor Length: 5.64"
Shaft Keyway: 3/16" and runs the full length of the shaft
The specs on the Rad2Go:
36 Volt DC 800 Watt,
3300 RPM Ventilated Permanent Magnet Motor
Dimensions: 5-1/2" long by 4-3/8" diameter
Weight: 10lbs
The Rad2Go 800W is the biggest motor available in scooter / electric pocket bike type bikes. The Etek can be retrofitted into a frame, but it will require alot of work.
Hope that helped.
Originally Posted by ROAMONEZ One more question how big is the etek compare to the razor motor.Not wattage but actual size. |
