MX650 mods?
A new drag bike
Xp-700
pr200 razor-mod
help with razor pr200 set-up
Electric X7
Old 06-16-2009   #1
which one is better?
which would give me better performance
a 36 volt 1000 watt motor over-volted to 48 volts or
a 48 volt 1000 watt motor with 48 volts?
hudabom246 is offline   Reply With Quote
Old 06-23-2009   #2
Re: which one is better?
They would probably be pretty similiar, but the 36v motor over volted to 48v would be cheaper but it would over heat faster. The other option would be more expensive but would be more durable. I would go with the 36v motor and 48v of power.
NecessaryEvil is offline   Reply With Quote
Old 06-28-2009   #3
if you overvolt a motor, you crank up the rpms, resulting in you going faster. But as NecessaryEvil said, it would also heat faster. If I am not mistaken, the 36V 1000Watt motor at 48 volts will spin faster than the 48V motor at 48 volts. Remember: Watts = Voltage x Amperage. Using simple math, the motor would need 20.8 amps. Your batteries might not last long.
kmmdw is offline   Reply With Quote
Page generated in 0.16723 seconds with 23 queries
