MX650 mods?
A new drag bike
Xp-700
pr200 razor-mod
help with razor pr200 set-up
Electric X7
Old 07-01-2009   #1
please help w/mx500
i have got a mx500 from a friend and i just replaced the battery when i turnd it on the chain would move but not the tire anyone know why???? (battery was straight out the box and is charging now)
mmx500 is offline   Reply With Quote
Old 07-01-2009   #2
PBP Administrator
nick's Avatar
Re: please help w/mx500
I believe the rear wheel on those is a "Freewheel" setup like on a bike, It's a ratchet type setup and I bit it broke.
I would try to pull the wheel off and test it, Or find a new one.
Nick.
nick is offline   Reply With Quote
Old 07-01-2009   #3
losen up the rear axle and take off the whole back wheel then you will be able to check everything out more closly...
make sure the tire spins freely on the axle without the chain and like what nickj said... make sure the freewheel is working properly along with the bearings
and what ever the problem is, it should be easy notesible when you take off the back wheel
supergoober206 is offline   Reply With Quote
Old 07-02-2009   #4
If you disconnected the motor wires make sure the wires are not reversed. If the motor runs in reverse the sprockets will “free-wheel”.
67camaro is offline   Reply With Quote
Page generated in 0.23330 seconds with 26 queries
