Originally Posted by hudabom246 alright thanks. im 14 and dont know how to weld so i was just wondering if there was an alternative. i was thinking bolts but i just wanted a second opinion. thanks.
another thing. im like 5' and 100 pounds. will the pr200 be comfortable? |
Well that gives you a tip on what you're gonna need.
Angle grinders, bench grinder, cordless/corded drills, dremels, battery load tester, zip ties (
), and last a welder
Welding will be the first skill you're ging to need if you want to do any modifications at all.
Go to your nearest Harbor Freight and find their 90A Flux Core Welder.
Personally have one, and it does great once you get used to it. If I can weld when I was 13, with only online forum posts as tips, then you can no doubt do it too
