MX650 mods?
A new drag bike
Xp-700
pr200 razor-mod
help with razor pr200 set-up
Electric X7
Old 04-10-2005   #1
RAM Electric Supercharger
Amazing what they do .may be a smaller one could be made to fit the motos. http://www.electricsupercharger.com/ see the Video demo on the site wow
You could use 7.2 volt RC racing motor as the power unit and a small 5-blade fan taken from a hair drier and mount it in a tube. Much cheaper to run than NOZ. (Think I will have a try at making one stand by)
stevie-jmmcc is offline   Reply With Quote
Old 04-10-2005   #2
Will the e-RAM work on a carbureted engine
22. Will the e-RAM work on a carbureted engine?
Answer: Yes! The e-RAM works with carbureted engines. You just have to make sure you follow the following guidelines: An e-RAM-FILTER should be placed on the end of the sealed intake tube that feeds the carb with pressurized air. The area between the e-RAM thrust and the carb will be a pressurized area, and this area will need to be linked with a tube to the float bowl vent of the carb to equalize the pressure between the air intake and the float bowls to assure proper fuel delivery (please contact us by e-mail if you would like a picture diagram of this setup, as we have done this many times with other customers).
NOTE: 2-stroke engines with simple membrane style carburetors will not respond to the e-RAM pressure, as this style carburetor delivers fuel based on vacuum measured by the membrane, and there is no method to equalize the pressure to make this style of carburetor work properly with the e-RAM. Your carburetor must have a "float-bowl" for correct fuel delivery. Also, if your fuel delivery is "gravity feed" type (like on motorcycles with gas tank above the engine), you will need to add a small fuel pump to provide pressurized fuel delivery to the carburetor at a minimum of 2psi.
Old 04-10-2005   #3
you will also need a rotary exhaust valve, or poppet exhaust valve. Since transfers are open at the same time as exh. port, how else do you expect to keep the boost in. This is more of a gimmick than anything. cheers
ryan is offline   Reply With Quote
Electric stater smoking wont turn over fast HELP pocketbiker1 2Stroke Midbikes 6 03-10-2007 01:47 PM
my neighbor cant decide gopeder123 Electric Pocketbikes 31 10-14-2005 03:34 PM
NOS KIT!!!! is it any good?? pix included u sucker just got served 2Stroke Midbikes 45 04-25-2005 02:28 PM
electric start want work Bighomedog11 2Stroke Midbikes 29 02-22-2005 06:58 PM
umm electric... moter_boy Electric Pocketbikes 1 01-26-2005 08:25 AM
Page generated in 0.23457 seconds with 24 queries
