MX650 mods?
A new drag bike
Xp-700
help with razor pr200 set-up
Electric X7
"That Black X1"
Old 06-26-2005
razor pocket rocket
i bought a 900 watt motor couple days back and i cann't put it where i had my 300 watt motor can somebody help me to find a spot for it.If i add a 36volt battery and a 900 watt battery how fast will it go and where can i buy a mph guage for it.
Old 06-27-2005
SEVO's Avatar
Electric PB Guru
The mounting for the 900W is very different than for the 300W. You may need to add a bracket to hold the 900W motor and then bolt it in that way.
Your Razor is 24V right? You'll also need to figure out where to add the third battery. As far as top speed, that depends on gear ratio's, tire size and how much controller you have.
If you try using the stock controller with that motor, you'll fry it. You'll need to upgrade the controller for that motor.
For speed, the best bet is to visit a local cycle shop and get a adjustable bicycle speedometer (computer). You can program it for your tire size so it's accurate.They are pretty inexpensive and are easy to add on.
Good luck!
Old 06-27-2005
is their any guage i can use for my razor and if i don't want 3 battery what can i use instead of it.
Old 06-27-2005
SEVO's Avatar
Electric PB Guru
The speedo isn't connected to your batteries. It has it's own internal battery.
You can run the 900W motor at 24V, but your speed will be a little less...you'll still need a larger controller to handle the amps.
Old 06-29-2005
aproldan's Avatar
Angry
i'm not an expert but i know for a fact there is no room for a 900 watt motor on the razor pocket rocket. and more bad news. there is no room to add another battery. you are going to have to start from scratch. and buy a new from bigger then the razor. if you decide to run your motor @24 volt you know you will cut your rpm's by 1/3. so if your motor was running 2800 rpm @36 volts. now it will be running at 1866 rpm @ 24 volt...... you would be luck if you hit 10 mphthem rpm's so you will need to start with a bigger frame that will hold 3 batteries and the larger motor....... sorry
Old 07-14-2005
hey man i hav a razor pr200 also and mine is fast as hell stock and there is nothing wrong with them and you all probably race and think about top speed but i do stunts and im in a stunt team called "mini X treme" and if you all like doin stunts and you wanna join mini X treme then email me at crazysk8r777@yahoo.com and i will ask the owner if he will let you in and we have a website for it to and if you go check it out in this website(www.freewebs.com/minixtreme) you can become a member of it to and then we will put a picture of you pocket bike no matter if its a razor or not and we will put your bike pic there so when everone comes to the site they will see ur bike there and we will be adding more to it as we go along and just email me a message in my email(crazysk8r777@yahoo.com) and say i wanna become a mini x treme stunt rider and with that message put a picture of you best pocket bike and i will make you a mini x treme member and then we will make videos and such so email us fast.by.
Old 08-18-2005
purplesaxark's Avatar
Club PBP Member
mini extreme stunts
Originally Posted by razoracer777
hey man i hav a razor pr200 also and mine is fast as hell stock and there is nothing wrong with them and you all probably race and think about top speed but i do stunts and im in a stunt team called "mini X treme" and if you all like doin stunts and you wanna join mini X treme then email me at crazysk8r777@yahoo.com and i will ask the owner if he will let you in and we have a website for it to and if you go check it out in this website(www.freewebs.com/minixtreme) you can become a member of it to and then we will put a picture of you pocket bike no matter if its a razor or not and we will put your bike pic there so when everone comes to the site they will see ur bike there and we will be adding more to it as we go along and just email me a message in my email(crazysk8r777@yahoo.com) and say i wanna become a mini x treme stunt rider and with that message put a picture of you best pocket bike and i will make you a mini x treme member and then we will make Videos and such so email us fast.by.
this link doesn't open for your website. is there a new one?
Old 09-01-2005
How do i add a 2horsepower motor on a razor and wat would be the power i need for it and what would the controller be for a 2 horsepower motor please help becasue i bought 1 and i want to add it to my razor but i don't know how
  #9
Old 09-02-2005
maytag's Avatar
After reading about halfway through this post, I couldnt help but start laughing. It has got to be the longest sentence ever posted in pocketbikeplanet's history. Kinda cheated though by mixing in 19 "and"s.
? for those with ROCKET KEYS SuperMan69 Air Cooled Pocketbikes 10 07-05-2007 09:48 PM
Just another rocket key review..... Kevin Air Cooled Pocketbikes 4 11-28-2005 02:18 AM
Rocket Key for cateye ImSoMeGuY 2Stroke Midbikes 8 09-24-2005 02:20 PM
Rocket Key da_islandboy 2Stroke Midbikes 14 03-06-2005 03:09 PM
No increase in speed after rocket key? SSJDemon 2Stroke Midbikes 6 01-31-2005 10:08 PM
Page generated in 0.44130 seconds with 41 queries
