MX650 mods?
A new drag bike
Xp-700
pr200 razor-mod
help with razor pr200 set-up
Electric X7
Old 05-23-2009   #1
Slowing down PR200 Pocket Rocket
I have a Razor PR200 (Razor) Pocket Rocket that's for my three year old. I put training wheels on it and need to slow it down to about 1/2 it's speed (7 mph). What would be the best way to do this? A throttle modification or some how limit the moror output? I got 5 days before he comes home to see the bike.
748*2Risk is offline   Reply With Quote
Old 06-23-2009   #2
Re: Slowing down PR200 Pocket Rocket
its not really possible. tell him to not gun it all the way or something.
NecessaryEvil is offline   Reply With Quote
Old 06-24-2009   #3
He's a speed demon, wonder where he gets that from?
Old 06-26-2009   #4
it is very possible...
just get a lower amp control
i think it is a 24v 29amp
get a 24v 20-25amp
supergoober206 is offline   Reply With Quote
Old 06-26-2009   #5
That wont do anything but lower the acceleration. I know what I am talking about...
Old 06-27-2009   #6
How about this controller? 24 Volt 150 Watt Universal Speed & Voltage Controller
If it's only letting the motor control get 150 watts that's got to slow it down right.
Old 06-27-2009   #7
dude stfu you dont know.....
your just some stupied kid who thinks your the master
serisouly shut up
lower the amps will l;ower the top speed and give him more run time...
Old 06-27-2009   #8
serisouly shut up
and THATS A FACT
Old 06-27-2009   #9
go to razorama and get a e200 or e300 controller
al;l the wiringing should match up to your pr200 nicely
Old 06-27-2009   #10
I went to the site and it says the e200 and the pocket rocket have the same controller. Razor Control Module - CT201C6 I found out the motor is 150 watts, so would a 75 watt controller cut the speed in half?
Old 06-27-2009   #11
watts dont matter in this... you want to look at the amps
btw the stock motor is 250watt
but you just want a 24v control thats under 29amps
your probly have to do some reasearch online and take some time to find a good one
ill hit you back if i find a good one
Old 06-28-2009   #12
serisouly shut up
Lol, good job being ignorant. You really think lowering the amps by 4-5 will make a difference? No it wont. People who upgrade from a 30A controller to a 100A one only see a 5MPH gain but ALOT more torque... and thats a 70A difference. Lowering the amps by 5 would MAYBE decrease the top speed by 1MPH and the torque slightly. Know what you are talking about before you attempt to correct someone who does.
Old 06-28-2009   #13
AND THATS BECUASE YOU USE CHEAP *** CHINA CONTROLLERS THAT SAY THERE RATINGS ARE 100AMP WHEN THERE REALLY RUNNING 60AMPS!
UMMM... HOW DO YOU INCREASE SPEED OF A ELECTRIC VECHILE? YOU INCREASE THE AMOUT OF RPMS... HOW DO YOU INCREASE THE RPMS? YOU INCRESE THE AMPS GOING TO THE MOTOR... HOW DO YOU INCREASE AMPS GOING TO THE MOTOR? YOU GET A HIGHER RATING AMP CONTROL!
SO HOW DO YOU DECRAESE SPEED? A LOWER AMP CONTROL WILL ALLOW LESS AMPS TO THE MOTOR WICH WILL SLOW IT DOWN AND THE BATTERIES WILL LAST LONGER BECUASE YOUR NOT USING UP AS MUCH POWER AS WITH A HIGHER AMP CONTROL
by the way wiseass the amps coming from the control dont control the torque... the watts of the motor will control the torque
Old 06-28-2009   #14
The Kelly 100A controller that Streetridaz used isnt a cheap controller. VOLTS increase the RPM's and you need amps to get up to the max RPM's. Your idea of decreasing the amps by 4-5 wont do barely ANYTHING. WATTS increase the max RPM's. Instead of typing in caps trying to prove a false point Ill actually help this guy.--------------Ok so what you could do is get the 24v 12A controller from TNCScooters. It will make the bike take forever to get to top speed and it might lower it by 1-2MPH.
Old 06-28-2009   #15
yea beacuase street didnt have enuff powere from the batteries that the controller needs... you can go from 30 amps to 100amps and even 1000amps and get amazing speed along if your batteries can produce the amps....
and you seem to forget that hes loweering the speed not increasing it so decrease amps and going slower is more effective then increasing amps and go faster
oh and your trying to help?
what was your first reply? oh.. its not really possible.... bu bu bu bulllll ****
get a 20-25amp control and whahaa DONE PLAIN SIMPLE
THATS IT!!!
now stfu you ***
im done with this thread
Old 07-01-2009   #16
I found a 16 amp controller TNC Scooters (Scooter Sales and Service) but not a 12 amp. For $15 I might give it a try.
Old 07-01-2009   #17
dont get a 12amp that will bearly push the bike at 5mph
get the 16amp and it should work out nicely
Old 07-02-2009   #18
The 16 amp at tnc scooters is out of stock so I'm back on the hunt.
Old 07-02-2009   #19
PBP Administrator
nick's Avatar
NecessaryEvil And supergoober206, If you can't stop fighting you are both getting some time out.
I thank you both for helping, But PLEASE stop fighting.
Nick.
nick is offline   Reply With Quote
Old 07-03-2009   #20
Did my post not go through?
brandonb is offline   Reply With Quote
Page generated in 0.39119 seconds with 74 queries
