| Re: 06 x15 springs on an 06 x18? x18 shocks suck, what I did to mine,"if you don't mind spending about 40 bucks" is I took a x12 shock cut the spring down to size heated the last coil bent it as close to the next coil as it would go and ground it flat, also the shafts can be removed and in the x12 shock they have a hard rubber insert, what I did is cut a piece of that to fit in the x18 shock which eliminates bottoming out. Its kinda hard to explain the process if you never seen a x12 shock because they are a couple inches longer than a x18 shock, but with a little commen sence you can modify your x18 shock with a x12 shock. |
