Originally Posted by Hot_Rod_ sounds like a dead battery. when you measure a battery you need to use a load tester not just a voltmeter. try charging the bike and see what happens. if all else fails you might need a new battery. also check all connections from the battery to the relay and to the starter to make sure nothing is loose. RadioShack has some batteries for scooters. we get ours from a company named budget batteries here in the northwest. |
Didn't suspect the battery because I just completed a ride and it started really strong. But if there's one thing I learned about these bikes, you never know. I've got a spare battery, so I'll give that a try. By the way, in general, how's everybody's 110 x6 running?
