Turbo Pocketbike
pheonix? full sized?
x18 or x19
The X18-R Nitro Super Bike
SuperBike Free-For-All
Old 11-17-2009   #1
xlilpimpstab0ix's Avatar
110cc x7 Sparkless
I'm trying to find out what's wrong w/ my bike. I know that there is no spark when I try to start it. I press the electo starter and it just makes that sound where you're trying to start it but it doesn't start up. I had a feeling that it's the spark but I'm not exactly sure why it isn't sparking. What are some ways to test or diagnose this problem. Oh and I almost forgot...I just recently got a new NGK spark plug
xlilpimpstab0ix is offline   Reply With Quote
Old 11-17-2009   #2
www.extreme4strokes.com
Re: 110cc x7 Sparkless
Sounds like you are jumping to conclusions. You need to test for spark, take the plug out, leave it in the boot and resting on the cylinder head (it has to be grounded) and now crank the bike over and see if you see the spark. Is the engine turning over well? Have you tried starting fluid?
Old 11-17-2009   #3
Kevin
K-Pac's Avatar
if you find you have no spark, check over you coil and wiring. See if your coil is grounded and your wiring is correct. If you have another coil by hand, try it out and see if it is the same results.
K-Pac is offline   Reply With Quote
Old 11-17-2009   #4
Well before I posted this I did try to see if there is a spark by removing the plug from the cylinder and leaving it connected to the boot and then I pushed my electo starter but no spark on the plug. I think it might be my stator or my coil. It has to be either or. But I'm not sure yet. When I test my stator/magneto tomorrow I'll probably get better results and I'll hopefully be closer to figure out why my bike isn't starting.
Old 11-17-2009   #5
Oh and one more question. When you guys say ground the coil do you guys mean that the ignition coil is mounted onto the frame? If so then I'm pretty sure I have it mounted correctly. Anyone have any pictures of ignition coil mounting?
Old 11-20-2009   #6
SPB Mod Master
Holy crap man!!! what did you do.....lol j/k...After looking at your pics I now know why you dont have spark...If you would of posted them sooner youd be running already
First off you have the CDI box connected into the gearshifter readout plug...Look in the harness for another 6 wire plug plug like it with 5 wires...a blue/white stripe,,,yellow/black stripe,,,,,black/white stripe,,,,solid green,,,,black/redstripe wires in it...Thats the CDI plug...I have it edited in your photo
The coil looks like what da heck put it on...I dont see a green ground lug going to the coil body attachment screw coming from the harness.........It seems to be going to the rectifier mount screw;-thats wrong
After you make the corrections your bike will have spark again............
Below is what we mean by grounding the coil good...........Peace
Old 11-21-2009   #7
After you make the corrections your bike will start up again............
Thank you CAM for being alive! hahah. Now my bike will be alive. I think all I need now is carb tuning. What's the stocker tuning for the carb?
Old 11-21-2009   #8
SPB Mod Master
Middle clip setting on the slider needle c-clip and 2 turns out on the a/f mixture screw.Sparkplug gap .023'-.027"sae and make sure you have no kinks in your fuel delvery.....
Old 11-21-2009   #9
So I fixed what you told me to fix. What do you think? These are only temporary. The washers will come soon! haha. I got a nice blue spark but now I think I need help with the carb. Here are the pictures:
http://i46.tinypic.com/16tac6.jpg
http://i50.tinypic.com/2lbgyhc.jpg
http://i50.tinypic.com/t7zzh2.jpg
http://i49.tinypic.com/5394bm.jpg
http://i48.tinypic.com/2hhm42r.jpg
Old 11-21-2009   #10
SPB Mod Master
Yep thats the ticket.......Try removing the gas cap to check that theres gas in the tank then try opening up the floatbowl purge screw on the side of the floatbowl and see if the bowl has fuel and that a descent interrupted flow comes out of the black tube when the screw is loosened.....Check for that and get back to us with the results...
Old 11-21-2009   #11
alright so how do I fix the petcock from leaking gas. It's killing me. The petcock leaks when its on but then then it's off there is no leak.
Old 11-21-2009   #12
SPB Mod Master
Wheres the petcock? Is it the type thats built into the carb like the ATC 125's?Your o-ring may be stuck to the knob and stretches out when its "on" causing it to leak out
If so youre gonna have to drain the gastank and take the two screws that hold the plate and take it apart to see whats broke or stuck and fix it.Dont lose the wavy pressure washer..If it cant be repaired you can do the petcock mod thats done to the cag carbs with jb weld and eliminate it altogether and get a 1/4" shutoff from Ace hardware or get the repair parts through bike bandit ........
Old 11-21-2009   #13
It's not the carb petcock but the gas tank petcock that leaks when it's switched on, on.
Old 11-21-2009   #14
SPB Mod Master
You can take it apart with the two screws to see why its failing and if it cant be fixed you can do the same mod to that petcock too by removing it from the tank and then remove the petcocks knob and inner parts and fill up the void with 5 minute JB weld and when the jb cures you drill the fuel passage through with a 3/16" or 1/4" drill bit and slap it back on.............
Old 11-21-2009   #15
Will do! Thanks Cam
Old 11-21-2009   #16
Alright so this morning I fired up the bike and it started. I had to put the choke on tho. But then when I put the choke off it died but it would stay on if i steady the throttle. I think I need to fix my idle screw? What do you think cam?
Old 11-21-2009   #17
SPB Mod Master
It could be a bunch of things but the best things to start with is checking for an air leak and a fuel restriction
If theres no air leak or fuel restriction try richening the a/f screw 1/2 turn and setting the idle speed to 1500 rpms...
If those work but the bike still doesnt run right you can try lowering the needle on the c-clip on the barrelslider and tweaking the a/f screw and setting the idle..
If that still doesnt give a good result you may have to clean the carb or you may have to reset the float a tad richer even rejet the carb for the season...
Old 11-22-2009   #18
alright cool. I'll see what I can do. I really hate a cold start especially with the stupid season of winter! haha. Just playing. The only thing that's cool about winter is Christmas. Thanks cam
Old 11-22-2009   #19
These air cooled motors can take a while to warm up, if you are somewhere where the weather gets really cold and it is like 30-40 degrees when you start it then it will be quite a bit longer before you can shut the choke off. Also in the cold weather the air is much denser and therefore the bike needs to be richened up with the air/fuel mixture screw (I run a 158 jet in winter on my dirt bike vs a 155 in the summer)
Old 11-26-2009   #20
Kevin
K-Pac's Avatar
Hey yea like Bart said, my bike needs the choke to start nowadays as it is cold outside. Leave it running with the choke on for a little longer than usual then see what happens. (thats what I do)
Page generated in 0.34500 seconds with 76 queries
