You will need a bigger carb if you are doing a big bore. Otherwise you will be under-aspirated. The first thing you should do...if you have not yet done...is scrap your stock restrictive exhaust. Go with a big name like Pro Circuit, BBR, FMF ...we sell all these brands...our preference is the CHM 22mm. If you are doing a 88 cc BB then I recommend a 22mm carb and aftermarket exhaust. The results are significant...
Sid @ Genesis Autoworks, inc
916.685.0062 shop
Originally Posted by RossiniF1 thanx i will pm you when im ready for that, sounds like a couple things i have no clue about, will i need a bigger carb?? |
