Originally Posted by X7rocks i see that the x15 watercooled bike has that is it possible to buy them seperate so they can fit the x18? |
If that bike has dual frt brakes stock then you'll have to buy that front end along with the brakes, brake lines ect...the 18 forks are not set up for dual brakes, there is nothing to bolt a caliper to on the one fork leg and if you buy just one x18 fork with the caliper bracket thinking you can use that on the opposite side it won't work, the offset will not line up with the rotor.....
Other than for looks there is no reason for dual brakes on the front, these bikes don't do 200mph, I seriously doubt you will have brake fade with using just the one caliper and rotor unless you are racing and using the brake alot, then MAYBE.....
