Originally Posted by steven-d its the bit where u connect to the engin. Well my bro is not convinced the bike should be changing gears using so much force because that silver frame bit is bending on my bike are they bent on yours too ? |
not sure what u mean about the "silver frame bit" but the gear rod that's connected to the engine does flex a bit.. try not to change gear without the bike moving as more force is required to change gear...
you might just need to adjust the gear lever rod with the bolts.... it took me a cpl of different positions to get the right feel & the easiest to change..
u can also adjust the part that connects the "rod" to the engine undo the little screw and take it off and re-position it....
I have my rod at a comfortable position so i guess go off my positons.
