Turbo Pocketbike
pheonix? full sized?
x18 or x19
The X18-R Nitro Super Bike
SuperBike Free-For-All
Old 04-21-2005   #201
futronix's Avatar
Originally Posted by krsone
Yes I was up there today and got my parts (ignition $30, Gauge free, pickup free, sparkplug free and a better spring for the carb also free) so it was a good deal. I wanted to get the 22 tooth rear sprocket but he sold out and wasn't getting anymore in until tomorrow, Friday. I was not able to get any parts for you guys, he will only deal with the owner of each bike. and I also needed to tell him the invoice number on the receipt.
hmm. must give them a call tommorow and enquire about my speedo and order myself a 22tooth sprocket.... as for invoice number, never got one.... but he seems to know who i am everytime i ring so should be fine...... did ya get the price on the sprocket?
futronix is offline   Reply With Quote
Old 04-21-2005   #202
Box had a TNT recipet on it but chucked out box already dont know if i still have the recipet that i went to TNT place to claim the bike
steven-d is offline   Reply With Quote
Old 04-21-2005   #203
krsone's Avatar
he asked for my invoice number over the phone when he said he was going to send the parts over to me, if you never got one and he knows you got it off ebay then he should know its you.... he said the sprocket was $30 over the phone before I left. if you buy a rear sprocket and pay via netbank or paypall and ask for the dash at the same time then he will be more motivated to send it straight away
krsone is offline   Reply With Quote
Old 04-21-2005   #204
did he have any performnce parts at his shop like better exhaust etc and about the sprocket where can i get one he never has any parts for our imortals on his ebay shop
Old 04-21-2005   #205
krsone's Avatar
he's getting aftermarket exhausts in soon, I had a quick look at one on his bike. not sure if he's going to sell them on ebay. try and get him to send you a email with his details and transfer money via netbank is the easiest way.
Old 04-21-2005   #206
well im bored so im gonna post a picture of our bikes > 110cc(member of this forum) me and another friends chopper
http://www.pocketbikeplanet.com/gall...sort=1&cat=500
Old 04-21-2005   #207
krsone's Avatar
nice bikes, I think the imortals look alot better without the little plastic cups around the wheel hubs.
Old 04-23-2005   #208
have u found a new exhaust yet krsone ?
Old 04-23-2005   #209
futronix's Avatar
thought id fill ya in my latest problems.... when i changed the bearings last time we had to fix the cheap rod spacer that goes in between the bearings as it was a bit butchered when i was tryin to get the old bearings out.... a friend machined the rod and it came out straight but the problem was that it was less then a "mm short so it would not hold onto the bearings.... so today bought two new bearings as the "old" but "new" SKF's were going to be history once the OXy was onto them.. went to the friend machinist and got two new stainless steel rods put in... it was a bit of a b*** to measure them exactly but we got them right...
the new stainless steel rods weigh double the weight of the original spacers and I have no worries about the bearings caving in.
Old 04-23-2005   #210
So have u managed to fix everything now ?
Old 04-23-2005   #211
krsone's Avatar
haven't decided on a exhaust yet, I finally finished fibre glassing my inner side of the fairings though. there a bit heavier but should be
allot stronger, just waiting for them to dry. Tomorrow I going to reconnect my new ignition, its better than the stock. then try to get my alarm wired up might need a bit of help from futronix because the manual is a bit different than the wiring on the bike.
Old 04-23-2005   #212
krsone's Avatar
I decided to 2mm of the end of the inner bushing so it would sit freely and the guy at the shop said that would be fine. have you put the tires back on to see if there aligned properly?
Old 04-23-2005   #213
do any of your bikes smell ? cause my friend complaining about my bikes smell well to start then engin i have the choke down we is apprantly off as he took my air filter and checked but i try to start it with the choke on but it wont start
Old 04-23-2005   #214
futronix's Avatar
Everything on the bike is A1 except for the speedo which Im still waiting for!!!
Old 04-23-2005   #215
krsone's Avatar
not apart form whats normal. what dose it smell of, fuel? if its fuel then your carby might be flooding.. I don't really use the choke much I just put it on and kick start it to help prime the engine when its cold. if you have the choke on when the motor is on it will stall after a few seconds because of too much fuel.
Old 04-23-2005   #216
futronix's Avatar
yeah put the wheels back on and aligned it.... wheel is running straight...
u talking about "the guy" at CPB? I thought it would be ok to leave them sit freely but the annoying noise of it "chinging" around and the prospects of the bearings slightly caving in was enough for me to decide to do them properely...
im just about 100% confident in the bike ATM...
Old 04-23-2005   #217
futronix's Avatar
HaHa.. yes I had the same problem about the manual diagram being printed wrong..... It just happen that my mate found out the hard way first so I did it the right way..
glad to clear up nething your not sure about....
Old 04-23-2005   #218
futronix's Avatar
yes CHOKE "OFF" is DOWN.... your bike will smell for a bit.... how many mins u ridden it for??
my bike hardly starts with the choke on so dont worry, start it with the choke slightly "ON" or Completely "OFF", just let it warm up well before u ride it..
Old 04-23-2005   #219
krsone's Avatar
the guy at the bearing&bushing shop up the road from me.
good to see everything running smoothly.
Old 04-23-2005   #220
krsone's Avatar
Ill take some pix and make a diagram to make it easier to work out, just to be sure that I don't bugger things up again lol.
110cc X6 vs. 110cc X12??? Xerokewl10 4Stroke Midbikes 15 12-04-2005 08:46 PM
X6 110cc Owners Check This!!! TTMAN 4Stroke Midbikes 17 07-24-2005 10:01 PM
Imortal 110cc steven-d Air Cooled Pocketbikes 5 03-22-2005 12:04 AM
110cc Chopper VS 110cc Midbike system-TrojAn 4Stroke Midbikes 2 03-04-2005 06:21 AM
LUCKy 7 pocket BIKES how to fix problems?? weste47 Air Cooled Pocketbikes 7 08-30-2004 05:48 PM
Page generated in 0.40579 seconds with 78 queries
