Originally Posted by krsone I was getting sick of the screws that hold the fairing on falling out because of the 2mm thread in the brackets. so I welded nuts on the other side of the brackets so now when I attach the fairings the screw goes through the bracket and the nut on the other side.. If you do this make sure the threads line up to the hole by putting the bolt on with the screw tight against the bracket then weld it on. I hope this made sense.. |
I dont seem to have that problem...... then again im using high tensile allen key bolts that have a bit of tension on them so they dont shake loose....
good idea bout the nut but...
