Originally Posted by krsone my gears where a bit stiff when I got mine, it will get a little better over time. I adjusted the foot leaver downwards a bit and it helped shifting up. with the air gate adjuster (choke), I close it (pull up) Electric start for 2 sec or kick start once, then open it (push down) and electric start with a bit of throttle. the engine wont keep running if you got the choke on all the time its just help prime the engine. hmmmm silver balls, sounds like bearings.. check all your wheel bearings they could popped out. |
soundslike the neck bearings popped.Take the front brake and squeeze it hard and try rocking bike forward and back,if you feel play or hear a grumblimg or it shakes its the neck bearings.
