Turbo Pocketbike
pheonix? full sized?
x18 or x19
The X18-R Nitro Super Bike
SuperBike Free-For-All
Old 03-29-2005   #1
Question Imortal 110cc Problems need help
Hi everyone I just got my 110cc 4 stroke imortal today and this is my first bike ever. I was wondering if anyone else who has this bike had experiences a stiff gear shifter and found it hard to shift up and down and did anyone also have problems with the air gate adjuster when u have it to start the engine with it on then switch it off after the engine was warm, I found it when I turned it off the engine would also turn off. I also found a few little silver balls wondering where they came from.
Any help would be appreciated
Thanks
steven-d is offline   Reply With Quote
Old 03-29-2005   #2
krsone's Avatar
my gears where a bit stiff when I got mine, it will get a little better over time. I adjusted the foot leaver downwards a bit and it helped shifting up. with the air gate adjuster (choke), I close it (pull up) Electric start for 2 sec or kick start once, then open it (push down) and electric start with a bit of throttle. the engine wont keep running if you got the choke on all the time its just help prime the engine. hmmmm silver balls, sounds like bearings.. check all your wheel bearings they could popped out.
krsone is offline   Reply With Quote
Old 03-30-2005   #3
Yep the bearings poped
Old 03-30-2005   #4
krsone's Avatar
ok, same thing happened to me within 10min of riding. don't get crazy pocket bikes to replace them coz it might happen again you would be better off getting some decent bearings. I got NTN bearings the serial is 6201ZZ/2AS. getting the bearings out is a pain in the A$$, so I would get them taken out professionally. the wheel will spin better than it ever would with the Chinese bearings.
Old 03-30-2005   #5
I was told to get these ones ktm 6201Lu
Did you also receive the bike with any cracks or damages to the bike. I received mine with a cracked shield and some of the paint scratched of on the fairings and the brake handles
Old 03-30-2005   #6
Do you know if KTM are reliable and if they are any good ?
Old 03-30-2005   #7
krsone's Avatar
that would be fine as long as there good quality. I went to pick the bike up and checked it out before I purchased it, it didn't have any cracks in it. It probably happen while it was shipped to you.
Old 03-30-2005   #8
krsone's Avatar
where abouts are they made and who are you getting them off?
Old 03-30-2005   #9
I called crazy pocket bikes but I didn’t ask them to replace it I just asked them for the size and stuff so I rang a local motorbike shop called Robbo's motorcycles and they had these KTM bearings in stock.
Old 03-30-2005   #10
krsone's Avatar
take the wheel with you so they can use a bearing puller to get the old ones out
and maybe they could fit them in for you as well, it'll save you allot of work.
Old 03-30-2005   #11
me and my friend have already take out the wheel but we are not sure if the bearing are out when we took the wheel there were just circly bits of metals that were all crushed and kinda disintergrated.
Old 03-30-2005   #12
krsone's Avatar
the outer ring is the hard part.
Old 03-31-2005   #13
$15 per bearing and $20-30 installation fee
Old 03-31-2005   #14
krsone's Avatar
I guess that's ok, I cost me $12 per bearing and I installed it myself. as I said, its very hard to take out yourself without the proper equipment (oxy), so it might be worth paying installation fee.
Old 03-31-2005   #15
futronix's Avatar
Exclamation
Is the installation charge per wheel and does that include the removal of the old bearings!!!
futronix is offline   Reply With Quote
Old 04-01-2005   #16
I think that all of the bearings are our already they were crushed that bad i guess there were a total of 8 rings from the rear wheel. Installtion of the bearing and for the bearings them selfs and taking them out if they are still there is $50-$60
Old 04-01-2005   #17
futronix's Avatar
If you havent got access to an oxy I would say pay for the removal and installation it will save you a lot of time & energy.......
Old 04-01-2005   #18
Yep i hear everyone had a pain in the @$$ trying to get them out.
Do you know by chance which of the bearings are better and more trusted ?
KTM bearings serial is ktm6201Lu
NTN bearings serial is 6201ZZ/2AS
Old 04-01-2005   #19
futronix's Avatar
I personally put SKF's because I have used them before and know they are good quality. I wouldnt go to the extreme and buy real expensive bearings because the rim itself and its internals arent the best (internal rods and shafts aren't straight) and the difference in performance wont be noticeable.....
Old 04-01-2005   #20
Well i rang crazy pocket bikes and they said Ktm and krsone told me about the ntn ones
110cc X6 vs. 110cc X12??? Xerokewl10 4Stroke Midbikes 15 12-04-2005 08:46 PM
X6 110cc Owners Check This!!! TTMAN 4Stroke Midbikes 17 07-24-2005 10:01 PM
Imortal 110cc steven-d Air Cooled Pocketbikes 5 03-22-2005 12:04 AM
110cc Chopper VS 110cc Midbike system-TrojAn 4Stroke Midbikes 2 03-04-2005 06:21 AM
LUCKy 7 pocket BIKES how to fix problems?? weste47 Air Cooled Pocketbikes 7 08-30-2004 05:48 PM
Page generated in 0.85109 seconds with 315 queries
