| Re: This is an important question I need answered!! I bought the optional motorcycle dashboard................
Then I took apart the stock gauge cluster and took a dremel with a circular saw style cutting blade wheel and cut out the digital gear read out leaving enough clear acrylic plastic to encase the digital face in on all sides.It has its own wire harness plug..................Be careful of the way you handle it too because I had to resolder a few diode connections from overhandling in the area of all the little diodes connected to the wires that make the number shapes..........
Then I took a dremel and dremeled the lower left hole open larger..................After that I took a heat gun and softened up the dash case and stretched the lower part of the case with my finger to reshape it so the digital readout fit between the vapor computer and the outer dash skin and then I clear Rtv'd it in place.I also waterproofed the little diodes with clear rtv..............Peace
