Originally Posted by kbm OK, here is the story. I just received a new B1 110cc manual clutch bike. The front brake hydraulic cylinder assembly has 2 metal posts were I think there should be wires to connect to the rear brake light. I can not find any wires that go here and have no rear brake light. The wires going from the rear brake light lead to clutch?? What’s up? |
none of the B1 immortals come with the rear brake might connected. the two wires on each brake lever is what u need to connect in order to get it working..
it is basically a simple loop system : provide 12volts to one wire off the brake lever and connect the other wire to the brake light do the same for the other brake lever just use the same 12v source.... it took me about 20min to do but works well.....
BTW u will notice when u put ur headlights on that ur rear brake light comes on.... I simply cut the wire that provides the current to the brake light up near the wiring loom and used that to power the brake light from the brake lever switches....
Need anymore help on it let me know will draw up a diagram to explain....
