Originally Posted by Michael_K Come on krsone pls!! My bike will be here any min and I wanna get rid of that chinese oil asap!!!
Thanks |
if i were you i do the initial break in with the cheap chinese oil. they've prolly put assembly lube in the motor when they put it together and you will get it dirty quick with clutch debris. i would fire it up and run it thru all the gears first. after about 10min of riding change the oil.
ive got a couple pics to maybe help you out. with the drain plug ?
------ DISCLAIMER --------
These
photos are for educational purposes only. if you use these
photos to actually work on your bike you are doing it at your own risk and the author is not held physicaly, mentaly or financialy responsible for any damage which the user might incur.
----------End -------------
p.s just in case im wrong which i sometimes am unscrew the bolt slowly as not to have springs and such go flying.
