Originally Posted by Turb0TeK Over 1000 views come on ppl give me some questions or somthing. This is the 1st pocketbike ever with a turbo keep the post alive!!!!!!!!!!!!!!! |
Where can I get a small turbo like the one you have?
What are you using to controll your boost?
What brand waste gate?
Having any trouble with over boosting while shifting while have no blow off valve?
Any problems with over heating? Im assuming you tapped the block some where for oil for the turbo.
Can you post pics of where you drilled and tapped for your oil line to the turbo?
When are you gonna put a front mount intercooler?
Since boost is exponential, what are you using to add more fuel as your boost climbs whit your rpms?
Did you have to adjust or retard timing on the motor?
When will you have a kit available?
