Turbo Pocketbike
pheonix? full sized?
x18 or x19
The X18-R Nitro Super Bike
SuperBike Free-For-All
Old 02-04-2005   #1
krsone's Avatar
Arrow what 4 stroke is this???
Im thinking of getting this 70cc 4 Stroke, 4 Speed Semi Automatic
what is i called???
dose anyone own one of thease and dose it really do 46mph (75kph)
any info about this model would be a great help.
http://predator.bikepics.com/pics/ca...ics-285003.jpg
http://predator.bikepics.com/pics/ca...ics-285005.jpg
krsone is offline   Reply With Quote
Old 02-04-2005   #2
krsone's Avatar
...bump...
Old 02-04-2005   #3
driving4life's Avatar
This has been covered in several other threads but since I'm here I might as well tell you... It is a B1 Immortal bike except that one doesn't have the headlight they usually have. I've seen them on Ebay for $500 shipped.
driving4life is offline   Reply With Quote
Old 02-04-2005   #4
krsone's Avatar
thanks. yer I found all the threads soon after.
Old 02-04-2005   #5
No lights- horray.
thats excellent seeing as now we can take them to the tracks without having to tape all that rubbish up.
Nice one china
black-star is offline   Reply With Quote
Old 02-04-2005   #6
Where'd you find it and how much?
Old 02-05-2005   #7
krsone's Avatar
I found it on e-bay in Aus for $685 which is pretty good
and look how cool the Speedometer & Tachometer is.
vvvv
http://www.zekai.com/images/bikes/818/pic/pic818-05.JPG
Im stuck between that and
the other (with lights, red)
vvvv
http://i23.ebayimg.com/03/i/03/59/fc/66_1_b.JPG
but only small Speedometer. and that would probably go for $750
but shipping cheaper and shop is a 30min drive.
I really want lights but the blue and silver has a killah dash.
what do you guy think I should do?
Old 02-05-2005   #8
i got the one with lights. i haven't ridden it yet, and i'm gogin to go work on it right now...... i'll tell you how it runs. if you dont' wnat the lights and such and ur not gonna take it on the track, then i'd say u get lights(sorta confusing what i jus said). if you wnat it for show, i'd say get the lights
jongki13 is offline   Reply With Quote
Old 02-05-2005   #9
krsone's Avatar
I also have a cateye and I love the lights (just ads to the features). I was thinking of getting the one with lights then trying to find the dash that the blue one has (if its not to hard to hook up) and put that on.
how is the breaking power with the hydraulic disc brakes?? do you have the dual breaks with the drum on the back? and is the gear shifting easy?
Old 02-05-2005   #10
X-7-NOOBLET's Avatar
id say since its only 70cc itll be like shifting down (n,1,2,3,4) then u can prolly upshift but if not just keep goin and ull hit neutral.....
X-7-NOOBLET is offline   Reply With Quote
Old 02-05-2005   #11
Hot_Rod_'s Avatar
what is i called???
Not sure on the bike but i have gps'd a rx12 with the 70cc 4speed at 44.6 mph. the fourth gear was very long and i could not get full rpms out of it. im also a bit on the heavy side so i would say 46mph for somebody around 165lbs and on a long flat straight would be doable.
Hot_Rod_ is offline   Reply With Quote
Old 02-05-2005   #12
i jus rode my b1 imortal, and it's pretty dang fast. i sorta don't like the gearing thou cuz it's got like..... a seesaw gearing. you have to totally take ur foot off the back peg to shift and such.... sorta sucks.
i was going on a 35 mph street today and the cars were going like... 40. i was 3/4 reving it and i was going as fast as the cars on the street... pretty funny seeing the guy next to you just looking at you going the same speed
i'm not gonna ride it on the street any more thou... i skidded a couple times from going from 4-1.... i can go 0-1-2-3-4-0-1-2-3-4-3-2-1-0. my foot jus double shifted for some reason... pretty scary stuff
Old 02-06-2005   #13
krsone's Avatar
ok so if you were in 4th gear and you put it into 1st while turning a corner would you do a power slide and fall off (because the rear wheel locking up)?
so what if you rev it to high on a low gear can it screw the motor?
do you have a rpm gauge as well as Speedo?
Old 02-06-2005   #14
naw, there's only a speedo, and a gear meter thing that tells you what gear ur in. i have acutally went from 4.n.1 and.... slid and messed up my 0 thing that tightens the back(i have spares) it was quite scary. you would do a powerslide and fall off for sure. if u rev i ttoo high i think there's a rev limiter, so u'd be fine
hope that helped
Jong-ki
Old 02-06-2005   #15
krsone's Avatar
hope that helped
Jong-ki
0 thing, what do you mean?
Old 02-07-2005   #16
Post some detailed pics please!!
ctroost is offline   Reply With Quote
Old 02-08-2005   #17
krsone's Avatar
I have decided to wait until monday, the guy at the shop said he's getting 110cc in for $300 more. cant fuking wait!
Old 02-08-2005   #18
sorry, i cannot post detailed pics right now cuz my bro took my digi to college. ummm, the O thing i was talking about looks like this: O-| and it's a screw that tightens up the chain. it's after the axle bolt/nut. i sorta tore it.... it was pretty bad. i got better at shifting thou. now i can rev match(not toooooo well, but good enough for me). it's pretty sick. i jus sorta wish my bike had a bit more power... and longer first and second gears....
Old 02-09-2005   #19
krsone's Avatar
Im glad I didnt bid for the 70cc because of what you said about the power, 110cc should be enough for the moment, then ill start modding
Old 02-28-2005   #20
zero4's Avatar
moved to 4T forum
fasteR? 50 cc 4 stroke or 50 cc 2 stroke ph600 Chat 6 07-28-2005 04:06 PM
4 stroke exhaust on X6/X7 driving4life 2Stroke Midbikes 15 05-03-2005 04:43 PM
PRP has all 4 stroke bikes in stock 50cc-125cc with clutch or with out!! pocket rocket pro 4Stroke Midbikes 0 04-04-2005 04:10 PM
Breath deeply then exhale...4 stroke pipe combo on sale genesisautoworks 4Stroke Midbikes 7 03-27-2005 10:50 AM
Page generated in 0.34017 seconds with 76 queries
