Originally Posted by MelloCag Do you think $300 will cover everything you have listed especially if they have no connections with a machine shop? Not trying to sound funny but just asking a logical question..  |
yes it will a machine shop should charge you anymore than $60 to mill your head because for this single sylinder heads it isnt more than an hours work...the exhaust will cost you about $140..you can port the motor as well as advance the timing a lil for free (all you need is a dremel)...and the sprockets will cost you around $70...you should have no problem getting it done for under $300
