OK guys well im going to start on monday Im not going to make thr front fender as it is useless imop any one have problem with that also no rear fender either.I dont have those pices I threw them away long ago.Dose any one want stands.?IMMAKEING MORE.? The body I was thinking of thining down the rear end.Also the side panels I was thinking of eliminateing the hole and the body lines IM going to round out the front kind of bulbis.also no more wind screen at least that you can see through.IT will double as a number plate.Also remove the useless air vents in the front.So im truing to brake the fairings down to in to two to three pices .Fore ease of removeal Now the fairings are going to be bare Ie no paint At most white gel coat.Als i have been thinking of makeing some out of carbon fiber,but i think the cost will be to much.but it would be bad ***.clear reson with the corbon fiber visable.....SO INPUT INPUT>>>>>
Originally Posted by Joe Mason I would want a set for the X6 and X12.I'm in Bellflower Ca so you are close to me. |
