| Re: X18 Kick Start Problem The best way whould be to buy a new kickstarter shaft and install it...If you try to press it on it will strip in a short time and if you weld it youll probably burn the seal out of the casing and cause further problems for down the road when youll need to clean the oil screen or replace the clutch.If youre handy enough to drill through the center of the shaft and the kicker you can fix it with a thin bolt/nut and depending on how much you kick on it will determine how long it will last.........Peace
