| Re: x19 starting problems Just because the guy put a new battery doesnt mean he charged it correctly...If he used anything higher than 2 amps to charge it up then he cooked the battery...take it out and bring it to walmart autocenter and have it tested to be 100% sure....Overcranking the starter will cook the battery too .the starter isnt supposed to be cranked for longer than 5-8 seconds continuously and no more than 5-8 consecutive tries before having to wait 10-15 minutes for the starter to cool down....The cheesy batteries in these bikes are made for alarm syatem and emergency lighting back-up power supplys;-not to crank starter motors like the chinese try to use them for...the proper replacement for an electric start engine would be a wet acid filled maintainance free powersports battery from PepBoys..
Theres things you can do to your bike to make it run and startup fast,,theres a restrictor tab casted into the bottom of the floatbowl that needs to be grinded down to give the float its true range of motion its supposed to have..that tab is the chineses answer to getting an EPA certification on these bikes..Remove the carb,-totally disassemble it;-thouroughly clean it out;-check float height setting and perform the float restrictor tab removal mod,set the air/fuel screw to 2 turns out and change the oil with Castrol 10w/40 motorcycle engine oil;-not car oil and replace the sparkplug with an NGK C7HSA sparkplug and your bike should run pretty good after that if you do everything accurately,correctly and with an attention to detail...
