| X6 4 stroke clutch question I got my x6 used about 3 weeks ago for $200 (the bike wouldnt start and the previous owner didnt know it was because the starter chain wasnt on lol)...so i started by opening up the exhaust port, removed the weld material inside the header pipe, advanced the timing, rejetted the carb, port matched the intake manifold, removed the governor, put a cone filter on, and thats it..bike runs GREEEAAATTT but im pretty sure its not a 50cc because even stock i was killing many of my friends 50cc x7s...but my question is where the hell is the clutch in this thing...due to my porting on the intake side of the head, the low end bog has gotten even worse because its engaging too low so i would like to remove and lighten it...if anyone can explain to me where it is or if you have any pics ill be very greatful....oh by the way next upgrade after the clutch is lightening the flywheel and milling the head...if you notice im doing as many mods as i can to the stock motor for cheap...all walk throughs will be posted once i have completed |
