Hey fellas. i stripped a 50cc 4 stroke lifan down the other day so i took a few pics for future reference if anyones curious.
main question i have though is what upgrade options are there? not interested in small mods - the thing is so slow with the 50cc - was more thinking along the lines of a much bigger barrel.
is it possible to just slap on a 140cc + barrel onto the cases with a new piston? can i reuse the old head and cam? (dont think i can but might as well ask)
unfortunately i cant upgrade the entire motor in this because it has an extended output shaft so standard motors wont line up by a long way. so i have to deal with the crappy automatic transmission.
still studying the crankcases on the lifan exploded diagrams and to me it looks like the cases are pretty well universal across all motors. so im thinking i could possibly put the manual internals in there with the existing extended final drive shaft and make it work... what do you think? tried before?
but anyway heres a few pics.
cam and rockers
http://i849.photobucket.com/albums/a...n/DSC00619.jpg
top of the valves, where you do the adjusting
http://i849.photobucket.com/albums/a...n/DSC00620.jpg
equally tiny valves.
http://i849.photobucket.com/albums/a...n/DSC00616.jpg
tiny little piston
http://i849.photobucket.com/albums/a...n/DSC00621.jpg
overhanging gasket fail lol
http://i849.photobucket.com/albums/a...n/DSC00622.jpg
barrel without the head.
http://i849.photobucket.com/albums/a...n/DSC00614.jpg
stator side of the crankcase without starter motor. you can see how long the drive shaft is on this thing
http://i849.photobucket.com/albums/a...n/DSC00615.jpg
stator - you can see the low side is covered in black string, i thought it was burnt out at first!
http://i849.photobucket.com/albums/a...n/DSC00606.jpg
clutch and first half of the CVT
http://i849.photobucket.com/albums/a...n/DSC00610.jpg http://i849.photobucket.com/albums/a...n/DSC00611.jpg
havent split the cases but i doubt ill do that. still curious as to how the CVT works because i can see two long splined shafts inside but theres no belt drive within. only a gear down drive. so maybe it doesnt have a cvt after all and just straight gears down??
