Pics of your midbikes
Top Speed & Mods to get there
x7 top speed!!
a-nuter motor swap
Put down your top speed
Video
Midbike FAQ
Old 04-04-2005   #1
200cc 6.5hp catseye engine swap problems
I have purchased a unfinished project which is a 200cc 6.5hp loncin engine swap for a catseye and need some help to complete it.
it came with this lot done;
1. modified the frame,
2. engine mounted with in frame,
3. exhaust has been fitted but could do with slightly better set up,
4. set the carb up to work on the twist grip and tuned to produce more movement on the butterfly,
5. clutch system has been custom built to fit the engine including full adjustment,
6. sprockets have been lined up for twin chain system to work,
work to be done;
1.change the direction of the sprocket from the clutch to the secondary sprocket,
2.fit and modify the fairings
but to change the direction of the sprocket from the clutch to the secondary sprocket whould have been near impossible so i decided to turn the engine round the other way so that the clutch is on the left and the pull start is on the right but to fit it in had to remove the rear suspension (will have to reposition) and turn the wheel around but it was free wheeling the wrong way so i undid the sprocket and made it not free wheel but then when it would be trying to drive the bike it would be trying to undo the sprocket and wheel hub and also the chain is to short
so my problems are;
1. need a longer suspension but dont know where to get one from
2. when the bike would be trying to drive the wheel it would be undoing the sprocket
3. the chain is too short and dont know where to get a longer one from,
any help would be greatly appreciated,
catseye is offline   Reply With Quote
Old 04-04-2005   #2
fossil's Avatar
Try finding a 200cc motorcycle motor?
fossil is offline   Reply With Quote
Old 04-04-2005   #3
loco007's Avatar
200 CC 6.5 HP Hmmmmm
loco007 is offline   Reply With Quote
Old 04-04-2005   #4
im putting the same setup in mine its a B***H to do but weld the rear sproket so it will not come loose
Idk why the longer suspension is needed i dont need one for mine
and the chain ... just get a new rear chain and hook it up (take to local bike shop to size it up right)
how i need your help ... how did you get a #25 cultch alll i need is the clutchand i will be donesoo i just windein how you got it
CateyeRider is offline   Reply With Quote
Old 04-04-2005   #5
i need a longer suspension as the old one is in the way,
i took the chain to a bike shop and they said they didnt have any like it,
i bought the bike with the clutch on it
Old 04-04-2005   #6
if you can show a pic of it it would help but... if its a bar holding the cam cover i cut that(the one holding the electrical.. ill relocate that)
Old 04-05-2005   #7
if you give me your email address ill send you a pic,
what did you weld the sprocket to
Old 04-05-2005   #8
my email is xsemir315x@aol.com send some pix and ill paint where you should weld and could you take a pic of your cluch so i can see what it looks like
Old 04-05-2005   #9
Wrath7sins's Avatar
Originally Posted by catseye
so my problems are;
Look into obtaining the rear wheel and swingarm from an X7. The sprocket is bolted to the left side of the rear wheel instead of threaded, and the swingarm I believe is longer. I'll verify this when I pick my cateyes up from the machine shop.
I too have had trouble locating this chain. Especially the master links. I think it's an 8mm or something but it's absolutely not a #35.
Wrath7sins is offline   Reply With Quote
Old 04-05-2005   #10
have you found the chain yet if you have could you tell me where as i think i have found one that might fit from scooterpartsforless.com
is the x7 suspension longer to as i am looking for a longer suspension but idont know which one and where from
when are you picking up your bike from the machine shop
Old 04-05-2005   #11
Wrath7sins's Avatar
I think it may be. A friend of mine stumbled on to some master links, but we've yet to find the right chain locally. If you order one make sure to get the long (single chain model) one.
I'll know for sure when I pick up the bikes, but I believe it is. I know the X7 wheels are a larger diameter than the cateye, so if that's any indication...
I need to clean out the side area and build a bike shed. Right now our less-used bikes are being stored at my friends machine shop for lack of space here.
Old 04-05-2005   #12
I'll know for sure when I pick up the bikes, but I believe it is. I know the x7 wheels are a larger diameter than the cateye, so if that's any indication...
how hard do you think it would be to put the x7 rear wheel on the catseye,
is the wheel larger
Old 04-05-2005   #13
fossil's Avatar
provided you have enough clearance it might just be a matter of drilling and spacers. I've thought of that too, legal wheels on a cat bike hmmmm..
well its a start. I think you might want to throw in a cvt too.
Old 04-05-2005   #14
Wrath7sins's Avatar
Legal?
If you're referring to the X2 CVT I wouldn't. Those things have a hard enough time not burning up on a 49cc engine. If you're talking a gearbox, then yes, that's a given. And if multiple gears is a possibility, so much the better.
Old 04-06-2005   #15
so do you think the chains from scooterpartsforless.com
would fit
Old 04-06-2005   #16
minichopper's Avatar
Can you post pics so we can get an idea of what it looks like so far? I for one would like to see it.
minichopper is offline   Reply With Quote
Old 04-06-2005   #17
Wouldn't it be easier to just make or buy a locking hub and flip the wheel backwards?
Old 04-06-2005   #18
what do you mean?
how do you post pics?
Old 04-06-2005   #19
driftyx1's Avatar
Team gonads sells a racing hube lock that stops the sprocket from freewheeling that mite work for you instead of welding.To post pixs scroll down in the Reply to thread and click on manage attachments.
what do you mean?
driftyx1 is offline   Reply With Quote
Old 04-06-2005   #20
bu that still uses the thread and will unscrew itself
Engine Mount Modification snowboardgeek1 Air Cooled Pocketbikes 28 08-14-2005 02:41 PM
X1(cvt) engine swap need advice vasiliflame 2Stroke Midbikes 15 02-19-2005 05:14 PM
How To: Engine Mount Modification snowboardgeek1 Air Cooled Pocketbike How-To's 0 09-23-2004 08:59 AM
Midbike FAQ Outlaw50 2Stroke Midbikes 1 08-25-2004 02:08 PM
Page generated in 0.52245 seconds with 76 queries
