Pics of your midbikes
Top Speed & Mods to get there
x7 top speed!!
a-nuter motor swap
Put down your top speed
Video
Midbike FAQ
Old 05-27-2009   #1
49cc X7 help!!!
the problem is that the pocket bike will start and idle but when ever i turn the gas is will not rev higher and moves but not faster than 3 mph
bifromokc is offline   Reply With Quote
Old 05-27-2009   #2
dragonkeep2000's Avatar
Re: 49cc X7 help!!!
open the choke
Old 05-28-2009   #3
Re: 49cc X7 help!!!
ive driven it with the choke on and off. do you think anything is wrong with the engine because i took it to a professional shop that fixes pocket bikes and they told us to buy a new engine but i dont believe them. and ive clean the fuel line that connects the carb to the engine??
Old 05-28-2009   #4
StrayDawg63's Avatar
Re: 49cc X7 help!!!
How old is the fuel mixture in the bike?
Old 05-28-2009   #5
Re: 49cc X7 help!!!
you may need a new piston and set of rings .....or you may need a new clutch...........if it is the piston i would just rebuild the engine , it may cost around 40.00 to rebuild but at the same time you are doing that you can do any upgrades to the engine you were thinking about .........
Old 05-28-2009   #6
Re: 49cc X7 help!!!
i put new fuel in it everytime i start it.
ive checked the clutch and clutch springs look good but i havent taken the engine apart yet. do you think i will be able to find out the problem if i take it apart?
Old 05-29-2009   #7
Re: 49cc X7 help!!!
Where do you have the mixture screw set at? If you take the sparkplug out what does it look like? What oil to gas ratio are you mixing?
Old 05-29-2009   #8
Re: 49cc X7 help!!!
are you talking about the screw where you take a flathead screwdriver and turn it? if you are i have tried turning it at different position while i drive it and it still does the same thing. the spark plug looks good because the bike starts and i mix the gas mixture the bike manuel it gives me
Old 05-29-2009   #9
Re: 49cc X7 help!!!
Yes I'm talking about the brass colored straight headed screw on the side of the carb. Reset it to 2 1/2 turns out. If you are using what is said in the manuel (25:1) than your using to much oil. You sould be mixing a 32:1 or 40:1 ratio. I use 40:1 myself. When I asked you what the sparkplug looked like I want to know if it's black and greasy or white and dry? I want to know what color it is ok?
Old 05-30-2009   #10
Re: 49cc X7 help!!!
do you mean screw it out 2 1/2 out from when it is all the way screwed in? does it make any difference if you use too much oil? and spark plug is dry. and another thing is that when ever i turn the gas it bogs down at around 1000rpm to 1500rpm max
Old 05-30-2009   #11
Re: 49cc X7 help!!!
i mean the spark plug is black
Old 05-30-2009   #12
Re: 49cc X7 help!!!
Yes I mean to turn the mixture screw to the right (in) softly until it stops but don't tighten it than turn it 2 1/2 turns to the left (out). Well 25:1 is just too much oil in the mixture and it will cause sparkplugs to foul just like the black plug you have. So yes it does make a difference. Go get a new sparkplug NGK BM6A (5921) and reset the carb to 2 1/2 turns out. If that don't help you may need to clean the carb plus I would check the coil to flywheel gap and see if it's about the thickness of a business card or even reset it using a business card.
Old 05-30-2009   #13
Re: 49cc X7 help!!!
from your perspective do you think anything is wrong with the engine? and how am i suppose to clean the carb? and where is the coil located an how to reset sorry im new at this
Old 05-30-2009   #14
DaTonz's Avatar
Re: 49cc X7 help!!!
I had that problem with mine and the metering block on the carb was full of junk. It took about 10 min to take off, clean, and put back on.
DaTonz is offline   Reply With Quote
Old 05-30-2009   #15
Re: 49cc X7 help!!!
i looked at the carb and it was clean how am i suppose to clean it?
Old 05-30-2009   #16
DaTonz's Avatar
Re: 49cc X7 help!!!
Take it apart, wipe it down with a wire brush or steel wool. It might help to use a some kind of solvent like gas (not 2stroke mix), kerosene, or alcohol. Make sure it's dry when you put it back together.
Old 05-31-2009   #17
Re: 49cc X7 help!!!
The coil is under that plastic shroud around the motor. Just follow the sparkplug wire and it will take you right to the coil. There will be 2 bolts that hold the coil in place. Turn the flywheel so the magnet is facing up. Insert a business card between the coil and flywheel and loosen both bolts holding the coil in place. Let the coil drop on top of the business card and tighten the 2 bolts back up. Remove the card.
I'm thinking it's more of a carb problem either a dirty carb or just way out of tune or both.
Now if you want to check the motor take out the sparkplug and place a finger or thumb over the sparkplug hole and pull the pull start. If it tries to blow your finger off the hole than I would say the motor has good compression and the motor is good.
Old 07-06-2009   #18
Re: 49cc X7 help!!!
. nice little tips with the card and the carb screw.
espi69 is offline   Reply With Quote
Page generated in 0.38229 seconds with 69 queries
