Originally Posted by Pops Racer Pharohx;
From my research I believe it is #219 DID type timing chain.
This chain is normally used for cam timing chain in full size bikes. Because of this, they are single piece without a master link.
For identifcation, measure center to center between pins. It will be .315" (or 5/16"). The links are also solid without rollers.
Hope this helps,
Pops |
#219 chain is common in kart racing but more popular in europe and japan. its also know as a "euro" chain. there are more links per foot so kart racers use it so they can have a sprocket with the same diameter as a #35 chain sprocket but have more teeth. more teeth = more strength.
i had seen that this size of chain is used for timing chains for cars and even some motorcycles. however, DID isn't the only manufacturer of #219 chain. EK, Wipperman, and some generic suppliers also make this chain.
