Pics of your midbikes
Top Speed & Mods to get there
x7 top speed!!
a-nuter motor swap
Put down your top speed
Video
Midbike FAQ
Old 06-25-2005   #21
Originally Posted by StrayDawg63
Well frogger what size of fitting do you recomend for the boost bottle?
Threaded barbed fittings are almost impossible to find with the appropriate sized inside diameter that are not to large on the outside. The problem is most threaded barbed fittings have pipe threads which makes them relatively big given their small inside diameter.
With a small 13.5mm carb venturi, the smallest restriction in the tube (including the fittings) should be no smaller than about 7mm or about 5/16". My preference would be 10mm with such a carb size.
For the Do-It-Yourselfer, thin walled metal tubing (brass is easy to find) epoxied into place might be the best bet since the appropriate barbed fitting with an inside diameter that large would probably be too big to thread into the intake manifold depending on the application.
frogger is offline   Reply With Quote
Old 06-25-2005   #22
StrayDawg63's Avatar
If you get your brass fittings from a auto parts store their threads are smaller than if you get your brass fittings from the plumbing department at a hardware store (home DePot,lowe's,Ace's). I'll give that a try frogger the next time I do a boost bottle.
Old 06-25-2005   #23
You need what are usually called thin-walled fittings. The problem with using a large enough fitting is where the tube needs connect to the intake manifold. Often there just isnt a lot of room to drill a big enough hole for a large diameter fitting.
I've seen a lot of boost bottles (expensive ones at that) using 1/4" fuel tubing. The barbed fiiitngs for that tubing has an inside diameter of about 3mm or slightly less. No way that will work correctly.
Home made boost bottle review!!! u sucker just got served 2Stroke Midbikes 22 07-16-2005 03:14 PM
boost bottle test smn1 2Stroke Midbikes 10 07-06-2005 02:30 AM
Boost bottle black88 Air Cooled Pocketbikes 4 05-15-2005 08:46 PM
Bike doesn't run right after boost bottle install prepsbl0w 2Stroke Midbikes 5 12-11-2004 03:39 AM
Page generated in 0.18146 seconds with 24 queries
