Originally Posted by trick jet no pressure it a storage bottle for the backwash kicked out buy piston port engine in this case and then sucked back in by the piston in pulses ,piston going up and down by the intake opening same way it gets into the bottle, pressure wave from the piston desending into the cases some fuel air charge escapes into intake tact/carb so the bottles stores it until the suction caused by piston asendig sucks it back into the engine so no psi in bottle ! take off your airfilter and pinch off your bottles line start engine rev engine observe the fuel air charge being exspelled out of carb top (fine mist spraying out of carb) thats what piston port means piston is the valve thats closing off the intake hole to make primary compression in the cases.blah blah any way thats it for 2stroke 101 rite now its not super detailed so yall dont jump on me,just keeping it simple sorry about my spelling ,now Im going back out in the shop,got broken pb to repair. hope that helps some tracy |
Unfortunately that common explanation is also wrong.
Boost bottles must be one of the most misunderstood (and usually incorrectly built) add-ons in this hobby.
A boost bottle does not pressurize nor does it store air/fuel for any period of time.
A correctly engineered and installed boost bottle simply provides a resonant space in the intake tract that attenuates the pressure pulse that would usually travel back out the carb causing a double rich condition.
To be effective, a boost bottle is engineered with very accurate specifications specific to the engine it is installed on. A proper boost bottle is tuned to an engine just like the expansion chamber on a tuned pipe.
The pressure pulse being sent from the cylinder back through the intake partially travels into the boost bottle and is reflected in a manner that helps cancel the pulses and keeps them from traveling back through the carb.
A boost bottle specifically handles pressure pulses (sound waves), not the air/fuel mixture.
With all the tutorials on making DIY boost bottles, almost every one of them has one glaring mistake. The inside diameter of the tube that connects the bottle to the intake manifold is almost always way too small to allow the boost bottle to be effective. The smallest inside diameter of the tube or any fitting should be no less that 1/2-1/3 the diameter of the carb venturi. So any boost bottle using tiny 1/8" ID or 3/16" ID barbed fittings is a complete waste and any noticeable performance enhancement with such crap is just wishful thinking. Most of the common fittings I see being recomended are 1/4" threaded barbed fittings. They too are much too small.
Also the volume of the tube must be calculated and included with the internal volume of the boost bottle for the appropriate size.
