| Re: CAM2 bottle boost For the double boost bottle setup I use long zerk fittings[grease fittings] and drill the stopperball spring cup out then I drill the opening with a 3/16" drill bit.drill and tap the manifold for a double boost bottle setup and add the zerk fittings...I let them poke down into the venturi and then I grind them flush with a grinding stone on a dremel and seal the tops with JB Weld....For the containers I used 2 spent Co2 canisters from my paintball gun;-drilled the tops and neck open with a 3/16" drillbit and hooked then to the intake with 5" of rubber line each..
For my single boost bottle on my stand-up scooter I used the aluminum float from the inside of propane cylinders.Below are pics of the propane cylinder gauge floats..Peace
